Top speed anyone?
JUNEX
traxxas-modifier said:
medichloreans said:
as i stated before..
msian distributor (Hong Leong Yamaha) do some modification on speedometer or speedometer gear...
that's why the bike easy to reach 175-180km/h...
traxxas...
yup..
stock tire..
F -70/90 Vee Rubber
R - 80/90 Vee Rubber
medich,
as stroker is saying, why did Hong leong modified speedo gear?
so does that mean all T135 in malaysia have this speedos modified,
and yamaha allowed it?
arent you guys complain about it? because its misleading...
[quote="Frozen Fire":2ijhkxg4]Well, this thread is made to post every top speed that you got, and don't forget to write down on what speed you changed your gear. First from me :
1st : 0-40 kmph
2nd : 40-70 kmph
3rd : 70-110 kmph
4th : 110kmph--- well I'm afraid to go any faster... you know how crowded and how bad Indonesian road :D
wow youve reached 110kph on 3rd gear,
Im using Hand clutch t135 Sniper Philippines and heres my max...
1st gear = 0-60kph
2nd gear =60-80kph
3rd gear = 80-100kph (FULL THROTTLE)
4th gear =100-115kph (still have throttle left but no more power)
how about other countries using Hand Clutch T135, whats your speed?[/quote:2ijhkxg4]
im using handclutch traxx :D here mine..
1st gear = 0 - 50 - 60kph
2nd gear = 60 - 80kph (until limiter)
3rd gear = 80 - 100kph
4th gear = 100 - 115 or 120 depends on the length of the road (Full off & on) HEAD DOWN..
chat_master08
traxx the fastest speed that i got from my bike is 125 kph... thats stock tires, 15/39 sprocket combination, with racing cams. but i never tried the 15/42 combination... we installed the 15/42 sprockets when i raced againts a raider 150.. and the my bike won by just a tire.. but now i never tried my bike againts a raider coz im still in break in process.. i cant wait...
orion79
stroker said:
Singapore fellas are getting between 120kph to a max of 140kph out of a stocker. Those with racing CDIs have recorded in excess of 160kph.
The bikes there too have a +10kph reading.
Cheers
hi guys!i live in greece with all the high temperatures and stuff..so i use a 20w-50 oil(castrol).my odometer now is showing nearly 6700 km.after having changed oil for the second time i was able to reach 140 km/h,full throttle of course,carrying also a second person..this happened riding downhill and in a straight line.my T135 is called crypton x(probably the european version)so here it is:1st-45km/h,2nd-70km/h,3rd-100km/h,4th-140km/h.i think its pretty cool for a motorcycle as this!i havent changed anything at all..my bike is standard.i believe that having the regularly scheduled services done in time will keep your bike in an excellent condition for many years.really proud riding a yamaha bike,i salute you all!!drive carefully!!
tashrey_888
hi guys... mine is 120 tops with dbs pipes stock gears,rejet main jet,stock cdi,stock tires my odo is 1800, honestly im happy with it fast thrill but surely kill.....
135lcSS
160km/h with my second model of LC in malaysia..std specs...i removed all the mod specs written on my name descp
lc-motospeed
160 then confirm ur speedo kuku edi, haha... my bike but not h/c last time oni managed to hit 140km/h after removing the air box n setting the bike like mad, haha... probably ur actual speed is bout 130km/h
135lcSS
ya lol lc-motospeed..lol i know the speedometer error thing lol.erm hey i know im kinda like off topics..but were still talking about top speed rite..any1 can tell me the actualy topspeed on malaysia FZ150i? i heard it can only run to 160km/h only... is it true..any1? please?
project R
my top speed?? around 180hk/h
1st gear 70km
2nd gear 115km/h
3rd gear 15+ km/h
4th gear 180
Impossible? heheheh try to change everything and wanna real speed just text me k
kid
weight :96kg
Cylinder blcok :65mm
Head : Racing head with big valve 22/19mm
Spring Valve : Racing custom made
Cam :Daytona Racing camshaft
Cdi: XP Andirion 301 stage 4 06 power - made follow my bike spec
Coil : Andirion 5A +ground strap
Carb : keihin sudco PJ 34mm
Clutch System : Modi
Magneto and Pulser Coil : Modi
Gear Box : Modi
Bearing : Full inside and out side (FAG C3 and SKF Explorer )
Throttle : Modi
Spark Plug : NGK G-Power
Spoket :16-35 415 DID ER
Tyr : front FDR MP 27..rear BT039 sss
Exhaust :Std Modi From Takim
other Mods : rear brake disc, fork,mono dan meter rpm koso
Gearing meter 135 :
Gear 1 : 110km/h rpm 13k
Gear 2 : 150++km/h rpm 13k
Gear 3 : 180++km/ rpm 13k
Gear 4: ++km/h,Rpm 14k out.... no idea
distance 1km...
p/s : i want sell my carb .. pm me if any one want it thx
ride safe bro
clearhearts
great ride KID..
my pet is all stock T135 machine.. i am in love with your bike bro..
top speed:
1st gear = 40kph
2nd gear = 70kph
3rd gear = 105kph
4th gear = 135kph racing back with Raider150 at 138kph.
i wish to ride up at least 150kph with little mods on the bike.
