TOPSPEED of your T135??
JapSpeed
mga master!!
anu po ts nio sa 14x42 sprocket combi. all stock po?
yun 14x38 kc skin 120kph yun ts all stock din.
may itataas pba yun ts ng mc ko? or gang 120kph lng talaga pag all stock dahil sa limiter?
tama po ba ako dun? hehehe
using 14/42? 120kph lng talaga, then you can hear the CDIs limiter
1st gear 35 kph
2nd gear 58 kph
3rd gear 77 kph
4th gear 98 kph
5yh gear 120 kph. "My Bike" not sure if same lng sa ibang bike...
pero this Top speed can be attained in just 500 to 700meters, maybe less
try 15/42, top speed 125kph.. basta hindi lng upwind
armand Cruz
my 120kph ts is for stock sprocket 14x38 combi. all stock.
then i changed to 14x42 combi. kaso di ko pa nanatry yun ts.
try ko muna sir jap yun 14x42 combi, if i'm not satisfied mgchange ako to 15x42 combi. all stock pati pipe.
thanks sa advise. ;)
armand Cruz
125kph ang ts ko sa 15x42 combi all stocks pati pipies, pero sabi ng frend ko na naka honda cbr150 nasa 130kph ndin daw yun takbo q nun sabay kasi kami nun.
sakin 15/39..ayos lng din sa arangkada at ts...engine stock, open pipe,..di ko pa ma-full ang throttle aabot na sa 125 kph..wala kasi super long straight road d2 samin e..less than 1km lng.
nabb diana
125 once all stock no changes oil yamalube Lang din di pa nka yuko flat ang road maybe Sa gear ko nkuha already running start from 2nd 60 3rd 90 4th 110 5th gear ko Yung nagpa 125 the stats are how i top every gears
JustinStock
Good Day Masters,
Can you please give me some advice which battery brand or capacity will be compatible for our uma digital speedo to avoid voltage fluctuation.
My Set. 62mm bore up, pnp stock head jvt valve spring, uma racing cdi, k1 stage 2 racing cam, r9 austin series racing exhaust, 28 mm nibbi round slide carb 38/120 jet sizes. uma hyper clutch. thank you in advance. God speed brothers.
jan_altab
1st gear 35 kph
2nd gear 58 kph
3rd gear 77 kph
4th gear 98 kph
yong mc ko 2 months old 105 lang top speed niya. baka umabot pa to ng 120 pag nag change ako ng sprocket . pwede din ba ang 15 /40? tnx
