afaik sir, it's fine, it still can attain high speeds but in long run & the prob is if you don't have long road unlike when there's no restriction, you can attain that top speed way more faster with extra top speed.Gud day!!! Tnx sir.. Sir, it's ok to use rcdi, stiffer v.s but I'm using my stock muffler or need to open pipe to match the setup?
a
afaik sir, it's fine, it still can attain high speeds but in long run & the prob is if you don't have long road unlike when there's no restriction, you can attain that top speed way more faster with extra top speed.[/QUOT
. Sir do you have an idea about the price of the rextor cdi and stiffer valve spring and all are genuine parts or there is a secondary?a
bro, san ka nakabili ng R9 pipe mu? magkano?update: Hit 125kph on straight road with 15/42 sprocket combi (R9 pipe, Denso side gap sparkplug, stock air filter paper remove and replace with 4 layers panty hose) rest, all stock![]()
below is the link sold by JapSpeed, last price was 3,300php....(pag abot bag-o pa kaayo murag wala nagamit walay mga takoling hehehe.)bro, san ka nakabili ng R9 pipe mu? magkano?
Top speed : 120km/h
Faito 60mm bore
Faito turbo cam
faito clutch plate
faito clutch spring
faito 7400 ignition coil
stock exaust
110/80-17 rear 90/80-17 front (looks like donuts )
14/39 gear ratio
plus after markect exausts are illegal to use on the street here . cdi im thinking about uma . carb im still learning ..Those upgrades will not only help top end but also in your acceleration. Can't you modify the stock exhaust? Aftermarket are illegal here in a lot of places as well but most tolerate things or people modify the stock pipe for better performance while still looking stock. Uma makes a goood carb as well since your going with an UMA cdi, might pair off well.brother , for meh its not about the kph its the accelerationplus after markect exausts are illegal to use on the street here . cdi im thinking about uma . carb im still learning ..
murang less than 1 hour ra tingali ako gamit ana. palit nako 5,500... dili pwede sa ako set up before, no choice ky kinahanglan nko mo palit ug lain nga pipe. pero sng nakita nko lipay ang buyer (Dropper) lipay na pd ko.. hehe! ride safe!!!below is the link sold by JapSpeed, last price was 3,300php....(pag abot bag-o pa kaayo murag wala nagamit walay mga takoling hehehe.)
http://yamahat135.com/threads/sold-r9-pipe-for-sniper-mx.19139/
can you please tell meh how i can get max acceleratoin i only need 120 top speed . i want full acceleration. AND THE EXAUST SOUND CANNOT BE LOUD .Those upgrades will not only help top end but also in your acceleration. Can't you modify the stock exhaust? Aftermarket are illegal here in a lot of places as well but most tolerate things or people modify the stock pipe for better performance while still looking stock. Uma makes a goood carb as well since your going with an UMA cdi, might pair off well.
If it's acceleration then i think that's mostly your gearing plus a good clutch to get the power to the ground. Obviously you need all the horsepower you can get to get either top end or acceleration. If you gear it for low top end you will get faster acceleration and vice versa. The gearing thing (#'s wise) always throws me off but it's all about ratios. Like if you have a car and the drive gear is 4.11 it will accelerate a lot faster than if the drive gear was 2.73... with 2.73 you can cruise down the highway and the engine will be very quiet (lower RPM's) at say 100 kph, but if it was using the 4.11 gears it would be using a higher RPM and be "noisier" ,,,, but would have reached 100 kph a lot quicker than the 4.11 drive,,,, same principle with the gearing of your bike.can you please tell meh how i can get max acceleratoin i only need 120 top speed . i want full acceleration. AND THE EXAUST SOUND CANNOT BE LOUD .
use close ratio gears..If it's acceleration then i think that's mostly your gearing plus a good clutch to get the power to the ground. Obviously you need all the horsepower you can get to get either top end or acceleration. If you gear it for low top end you will get faster acceleration and vice versa. The gearing thing (#'s wise) always throws me off but it's all about ratios. Like if you have a car and the drive gear is 4.11 it will accelerate a lot faster than if the drive gear was 2.73... with 2.73 you can cruise down the highway and the engine will be very quiet (lower RPM's) at say 100 kph, but if it was using the 4.11 gears it would be using a higher RPM and be "noisier" ,,,, but would have reached 100 kph a lot quicker than the 4.11 drive,,,, same principle with the gearing of your bike.
Many hear have played with the gears and can give better advice than me.
what kind of sniper/model do you have?can you please tell meh how i can get max acceleratoin i only need 120 top speed . i want full acceleration. AND THE EXAUST SOUND CANNOT BE LOUD .
cool ride! almost had me thinkin it was an SMX 135.
