TOPSPEED of your T135??
Denfox74
Gud day!!! Tnx sir.. Sir, it's ok to use rcdi, stiffer v.s but I'm using my stock muffler or need to open pipe to match the setup?
snipermxmalayaklan
a
afaik sir, it's fine, it still can attain high speeds but in long run & the prob is if you don't have long road unlike when there's no restriction, you can attain that top speed way more faster with extra top speed.
Denfox74
a
afaik sir, it's fine, it still can attain high speeds but in long run & the prob is if you don't have long road unlike when there's no restriction, you can attain that top speed way more faster with extra top speed.[/QUOT
a
. Sir do you have an idea about the price of the rextor cdi and stiffer valve spring and all are genuine parts or there is a secondary?
Dropper
update: Hit 125kph on straight road with 15/42 sprocket combi (R9 pipe, Denso side gap sparkplug, stock air filter paper remove and replace with 4 layers panty hose) rest, all stock :D
sixty-thirty
Top speed : 120km/h
Faito 60mm bore
Faito turbo cam
faito clutch plate
faito clutch spring
faito 7400 ignition coil
stock exaust
110/80-17 rear 90/80-17 front (looks like donuts )
14/39 gear ratio
tabi1
Top speed : 120km/h
Faito 60mm bore
Faito turbo cam
faito clutch plate
faito clutch spring
stock exaust
14/39 gear ratio
Time for CDI, carb, and exhaust upgrades,,, any head work yet? You got a lot more KPH's readily available i believe!!
sixty-thirty
brother , for meh its not about the kph its the acceleration ;) plus after markect exausts are illegal to use on the street here . cdi im thinking about uma . carb im still learning ..
tabi1
Those upgrades will not only help top end but also in your acceleration. Can't you modify the stock exhaust? Aftermarket are illegal here in a lot of places as well but most tolerate things or people modify the stock pipe for better performance while still looking stock. Uma makes a goood carb as well since your going with an UMA cdi, might pair off well.
JapSpeed
below is the link sold by JapSpeed, last price was 3,300php....(pag abot bag-o pa kaayo murag wala nagamit walay mga takoling hehehe.) :D
http://yamahat135.com/threads/sold-r9-pipe-for-sniper-mx.19139/
murang less than 1 hour ra tingali ako gamit ana. palit nako 5,500... dili pwede sa ako set up before, no choice ky kinahanglan nko mo palit ug lain nga pipe. pero sng nakita nko lipay ang buyer (Dropper) lipay na pd ko.. hehe! ride safe!!!
sixty-thirty
can you please tell meh how i can get max acceleratoin i only need 120 top speed . i want full acceleration. AND THE EXAUST SOUND CANNOT BE LOUD .
tabi1
If it's acceleration then i think that's mostly your gearing plus a good clutch to get the power to the ground. Obviously you need all the horsepower you can get to get either top end or acceleration. If you gear it for low top end you will get faster acceleration and vice versa. The gearing thing (#'s wise) always throws me off but it's all about ratios. Like if you have a car and the drive gear is 4.11 it will accelerate a lot faster than if the drive gear was 2.73... with 2.73 you can cruise down the highway and the engine will be very quiet (lower RPM's) at say 100 kph, but if it was using the 4.11 gears it would be using a higher RPM and be "noisier" ,,,, but would have reached 100 kph a lot quicker than the 4.11 drive,,,, same principle with the gearing of your bike.
Many hear have played with the gears and can give better advice than me.
JapSpeed
use close ratio gears..
sixty-thirty
i bought this cms set up few months ago , i didnt have time to install them ,what do you guys thing of this set up ?
cms gears
1st gear 31/12
2ng gear 29/16
3rd gear 23/17 (stock)
4th gear 23/20
stock gears
1st gear 34/12
2nd gear 30/16
3rd gear 23/17
4th gear 23/22
raven
cool ride! almost had me thinkin it was an SMX 135. :)
anyway, I'd go with @tabi1 's suggestion. it'll be hard to achieve what you want with a stock cdi. your rpm is limited. try some racing cdi's man. and you have to do something about the exhaust. there's this brand, "Nob1" but oncw you're hitting around 9000 rpm, it'll be noisy. look for someone who can modify your stock pipe. 60mm bore on that little exhaust aint gonna be healthy for your sniper.
as for the gear ratio and other specs, @kimredbull or @rowan maybe of assistance. ;)
sixty-thirty
now im curious what is the differance between smx and mine ? 0_o
bro i know the nob one brand but the exaust has to look stock from outside and be quite at the same time . i already did cut the end of the pipe with a - screw driver and a hammer keke .. and i did cut some internel parts too .. my friend said i should make 2 or 3 tiny holes under the exaust so when im at high rpm the exaust will flow from those holes too . but when im normaly driving it will be quite too .
