Uma Digital Meter
suiluj
if you want to reset Trip A or B , Tops Speed Record, Oil Mileage counter. simply LONG PRESS ( 3 Seconds is more than enought) THE RIGHT BUTTON (color black ) ubntil the indicator panel shows resets.... HTH. main ODOMETER READING will not reset by using this method...
ESOJ de GUZMAN JR
this is my uma digital meter. the only thing you can reset is the trip A, trip B, top speed record, oil mileage but the odo cannot reset. when reseting just hold the ADJUST button. the right side for 3secs. if you like to adjust the rpm gauge, time, tire circumference, oil mileage. just hold the SELECT and ADJUST button at the same time. it will appear the RPM adjustment.
menu 1. RPM,
menu 2. lo account - hi account,
menu 3. tire circumference,
menu 4. oil maintenance,
menu 5. time
menu 6. backlight
tabi1
menu 1. RPM,
menu 5. time
menu 6. backlight
Played with it a little before i left, this thing seems like a pain to learn to set things. I followed the manual and didnt really come out with anything positive other than setting the time. I was trying to do the screen color changes and it says hold high beam for .5 to 3 second, return to low beam and its supposed to change colors but i didnt see any changes. Have you figured it out?
Other than that the gauge has a lot of nice functions.
ESOJ de GUZMAN JR
thats my mc and my gauge. the background color will changed during switching the low to high to low beam @ 3secs. if doesnt work just repeat it.
gunkhean
I had a problem with my uma racing digital meter, the gas meter just suddenly not accurate at all! my tank is dried off but the reading in the meter show still have 60% of petrol in side the tank. I just use it not more than 6 month.
john_carlo
Check the floater inside the tank
gunkhean
I dun think is the tank float problem cause the gauge never show the actual quantity of petrol when the bike moving. when I switch of the key & turn on again the gauge will show the actual quantity of petrol.
john_carlo
If the bike is moving it will not show the rigght reeding because the floater is moving up and down inside while if the bike is at fest the floater is in stable pisition...
ESOJ de GUZMAN JR
agree with sir john. so if u want to check ur fuel level. take a nap (rest) when u reach 50km in your 1st trip. the 2 fuel bar indicator will disappear. next is 80km. hmmmm. it depends also about the load of engine and speed.
gunkhean
I already tried running with full tank, but I already running more than 100km the indicator still not moving, that's unusual practice. just now I tested the float with multimeter, there is no abnormal ohm (full position - 8 ohm, empty position 98 ohm)
