Bore Upgrading To Vixion
JVIC
sir
satified user here of vixion kit..even my block is still in brreak-it period,
you will noticed the additional power output..ofcourse, you need some
modification to maximize the performance of your bike..
all in all..Vixion Kit only is a super Upgrade..hurry, get one before its too late...:dance:
sir theres anything to do after installing the vixion kit???like port and polish or simply plug and play only????
rhoitol
it depends on you and your mechanic paps..you can plug and go or plug and slightly modified the Head..
fmark
what is the recommended jettings for stock carb using vixion kit? and where can i buy jettings? i have now vixion kit,cams and valve spring. i heard that it is needed to rejet the stock carb if you use it for vixion kit. also using stock pipe for the mean time. (no budget yet for open pipe)
speedyduckling
its better to change your stock carb sir.
and i recommend you to use a stock carb of r150 as per advised by my mechanic.
Kenshi
hmmm... this is my first choice for upgrade before but with all the write ups in here I'm beginning to think about it. I'm just afraid I might get a fake Vixion kit some say there are lots of fake Vixion kit now here in the Philippines. Anyone knows where we can get an original Vixion Kit?
rhoitol
pm kr.r_sniper sir..one of most trusted seller..
fmark
ok sir.thanks.for the mean time, i'll use stock carb, change MJ from stock carb of raider 150 carb while waiting for funds.;) hope everything will be ok,scheduled tomorrow.
rolando garra
Sir,
May ask you for help, because i have problem in my sniper 135 the main problem is leakage of oil output in muffler, any one can help me or neap shop along pasay road
Thank you,
with my vixion kit plus this mods my my "hinete" aka my rider reach 140kph on 3rd gear 300m then kaboom my engine explodes because of overrev and i didnt yet upgrade to BV ,so my snipee is under hospital now with a destroyed piston and block,valves that are cut into pieces and a damage but can revive head(raider valves)
vixion kit +additional mods:
pin 2mm
yypang cam 5.8 lift
rcdi
crg cspring and r.c.lining
28mm oko carb
lighten flywheel
PnP
STOCK VALVE SPRING(another cause of overrev and valve float)
and other minor mods.
additional mods after my sniper is done:
new vixion kit (ouch!)
big valves with right vspring(raider valves) to compensate with the higher comp of the engine
pin balance - lessen the vibration of the engine and to compensate with the load of the engine
21t 4thgear -to give more power to 4th gear
57mm dome type = higher comp
upgrade to 30mm and 32mm carb = depends if for daily use and race use
this set may follow with your vixion kit upgrade.. Its worthit. More HorsePower t135! :)
can i know what means of pin balance?
DeViLsToRm
Anybody use vixion here without base gasket?may i know if u also have to pocket valve the piston if base gasket remove?thanks...
