valve clearence
man_sate
longRanger$$ said:
carb uma sesuai tak tok long distance kalu blok 6omm... head tukar spring je....
salam...jez nak bg info....
carb uma ok tok long distance...sy hampir tiap2 minggu g jempol, N9...setakat ni ok la...blok 60 mm...lain org lain pendapat...
p/s: kalau xmembantu...abaikan je...huhuhu
kamen rider x
nizam88 said:
kalau tak lenjan, tak jdi masalah ar kot..
Jln jauh Maintain 140-160kmh takde halnye..lbh dr tu klau nk jln jauh2 kasi myk lbh skit la..
klau x mau jem..uma pun dh ok,pattentnya 100% copy design keihin pwk,bhnnya drg upgrade ble myk msk je carb tu jd sejuk cam dlm ice box..jln jauh xde hal la,janji angin myk set elok2..
nizam88
takut 1 je kau tak tahan.. carb besar, kejap2 la kau isi minyak.. hahaha.. nak2, kau 140 ~ 160.. hoho...
nizam88
uikh... carb brapa?? cam aku, pakai 28mm pun, aduhai.. sakit gak.. klu melaka - kl.. dlam 3 kali full tank kot...
kamen rider x
Main jet,pilot,timing,angin dan myk set cantik2 la bro..
Jln jauh2 throttle maintain je jgn byk drop gear perah2 je..
Klau gaya bwk ctu moto std pun leh jd myk kuat gak..
Lagi 1 plug bg kilat dlu,br bakar cantik..
Laju ble perlu je..
(ptg lori @ bas ble drg rapat dgn kita)
Hehehe..
longRanger$$
@ nizam....
kuat neguk minyak 2....
seting dah cun ker....? atau ko fulltrottle jer...
tapi ok gak jaga blok... kang nak jimat minyak blok pulak tergadai... hehehee
kirawin
td ade g kedai nak tanya pasal ekzoz meletop...sbb xde masa nak wat sendiri..cine tue gtau...fuel ngn angin xcukup....kalo xnak meletup...tukar carb...huhuhu
kpd otai2...kalo xnak tukar carb...n xnak meletup....leh wat x,.???
dinn977
agak2 piston knocking valve x , ?
kalu pkai blok 60 + highcam/spring cms, tanpa buat pocketvalve...,
kid
xnk wat pn bleh pakai gasket tebal sket..
dinn977
GhosT.Lordz said:
pocket valve tu yang ada lubang atas piston tu..yang bentuk pelik.uuhh
ko tgk gambar bwh..atas piston ada lekuk 4 biji..
nmpak besh la blok ni...
kat head da xde air lalu la kan? thermostat pun da xde function kan ?
water pum mcmner erk ?
kat water pump tu kan ade satu lubang air dr head... x ganggu kew ?
maaf la byak tye....
saya baru nak belajar....
:wink:
