I'd prefer the Vixion kit, although you can't really go wrong if you choose the JVT bore.
The reason I prefer the Vixion kit is because it has no cylinder liner. It is entirely made of Diasil -
http://www.rose-hulman.edu/~stienstr/me 328/Al_Si_hw3.pdf
No cylinder liner means the heat transfer properties of the Diasil (Vixion in this case) bore is way better than with conventional cylinders with steel liners, since the Diasil cylinder is made entirely of Aluminum-Silicon alloy. Please note that Chrome or Nikasil cylinders are made by hard coating the Chrome or Nikasil into the conventional steel liner. The heat transfer properties of the Diasil cylinder can be up to 60% better than conventional steel or plated cylinders -
http://bikeadvice.in/diasil-die-cast-aluminum-silicon-cylinder-normal-cylinders/
The Diasil cylinder is proprietary to Yamaha, meaning they invented and perfected the process. This was first used on their prototype MotoGP bikes, then on their R series sport bikes, and later on smaller displacement bikes when they felt they can mass produce it and lower their overall production cost.
If you're bike is superstock or uses the Vixion kit, and you feel like it's losing power because of lower compression or excessive blow-by, just change the piston rings and it should run better again. This is only if you or your mechanic know that there's nothing else wrong with your bike.
My 2 cents...thanks!
