Vixion Block Or Jvt 57mm?
ambokz
tis my first time to try engine upgrade with my stock snipey, plan to buy vixion kit 57mm (as per suggestions here)is it ok to use that kit with my a stock carb,valve spring,etc?tia masters...just want to have enlightenment,as it is my first engine mods.:)
suplado010
there will be no power if you dont change your cam,valve spring and cdi...
bhek_21
@abraham
Sir both are good.. Vixion Kit is okay since it is OEM of Yamaha.. But when it comes to race spec, JVT 57mm kit is the one,, IMHO..;)
@ambokz
There will be an additional power when you change to 57mm bore kit.. BUT it requires supporting upgrades to maximize the power it can bring out and you can be sure that there will be no trouble afterwards.. Maybe we can still hear feedbacks from masters out there.. ;)
suplado010
HAHA! grabe ang need for power mo sir ahh.. baka 62mm will do for you.. :)
maliit lang po kasi additional power ng vixion kit sa motor naten so kung hindi naten susuportahan ng ibang parts lalung hindi mo mararamdaman si vixion kit...
rowan
they were both good bkit pa kayo magtalo hehehe:D . you know what we do old vixion kit block with jvt piston . you can make it semi dome piston . after shaving your block at any desired limit.
bhek_21
im planning to get jvt 59 cb, is it good for stock head or need to change to bv head. thanks
Sir I think it's ok even your on stock head.. unless your engine compression is high, you can change to bv head.. this is a recommendation from a mechanic that I know.. Because a friend of mine uses already a 63mm bore but he didn't advices him to change into bv head since his engine compression is not that high..
suplado010
ah ok...thanks mga masters..gradual lang ung pag engine mods ko.hehehe
maganda niyan papa ipunin niyo nalang poh muna yung parts then tsaka niyo ipakabit ng sabay sabay..para isang baklasan lang..sayang din kasi labor..mahal pah naman labor sa sniper kasi napakahirap buksan...pagtanggal lang ng fairings nakakapagod nah..hehe
ambokz
Tama paps,yan ung nasa isip ko,pra sabay na ang pag install at pagbaklas,tas isang byaran lang sa labor.hehehe
