sir, wer did u bought ur 15/41 SSS set?blue308 said:SPROCKET
Brand: SSS
CHAIN
Brand: SSS
tibay-sniper said:bro, just wanna ask from a noob on chains
what the difference between
428
415
chains?!?!? cause im planning to change mine. please?! thanks
Sir, 428, 415, 420, etc is the width of the chain. Commonly refered to as chain size. 428 is wider than 420 and 415 so it will fit a 420 and 415 sprocket. But a 415 sprocket will not fit a 428 chain. And if you manage to bump into a chain size with a letter "H" preceeding the number, it means "heavy duty". 428 and 428H is the same width. The difference is the 428H has a thicker steel plate and heavier. It is better to match up your chain and sprocket sizes to avoid uneven wear. HTH.sniperCJ said:tibay-sniper said:bro, just wanna ask from a noob on chains
428
415
428
415
420
please inform us masters! TIA
ok sir. thanks a lot for the info, it really helps :idea:marvymavs said:Sir, 428, 415, 420, etc is the width of the chain. Commonly refered to as chain size. 428 is wider than 420 and 415 so it will fit a 420 and 415 sprocket. But a 415 sprocket will not fit a 428 chain. And if you manage to bump into a chain size with a letter "H" preceeding the number, it means "heavy duty". 428 and 428H is the same width. The difference is the 428H has a thicker steel plate and heavier. It is better to match up your chain and sprocket sizes to avoid uneven wear. HTH.sniperCJ said:tibay-sniper said:bro, just wanna ask from a noob on chains
428
415
428
415
420
raider125jeigh said:15 x 42
stock chain....YAMAHA RS100 42t sprocket...
planning to change with 15 x 40 by sunday...
