What's your current SPROCKET & CHAIN brand/size???
the_one
This topic will give us guide/survey on what brand/size of SPROCKET & CHAIN will be the best for your our T135 (Modified/Stock Engine)..
SPROCKET
Brand: MCS blue alloy
CHAIN
Brand: Japan Made
syfull
mine...16/41....stock chain....n i dunno(forgot) da brand of my sprocket..huhu nice acceleration though
tibay-sniper
stock sprocket and stock chain, planning to change it this month
OT sir baka pwede nating lagay yung presyo ng mga sprocket and chain sa mga nag change nah... para may basehan din
linjunvelasco
im using sss sprocket 15/42 and sss 415 chain , by the way there is a store in 10th ave kalookan who sells 415 size of chain if i remember Cyclone is the name of the shop..if anyone of you guys have broken their chain they have it
tibay-sniper
bro, just wanna ask from a noob on chains
what the difference between
428
415
chains?!?!? cause im planning to change mine. please?! thanks
zhaff
415 easy to slack n loose than 428..
usually cubprix(www.malaysiancubprix.com) use this size.
pin for chain 428 more big, thats good for long distance.
u must survey size 420.. not bad.
what is the best combinatian of sprocket for stock engine???
X1rCJ
blue308 said:
SPROCKET
Brand: SSS
CHAIN
Brand: SSS
sir, wer did u bought ur 15/41 SSS set?
i really want that kind of combi. its hard to
find that combi 4 SSS. TIA sir. :)
X1rCJ
428
415
428
415
420
please inform us masters! TIA
marvymavs
428
415
428
415
420
Sir, 428, 415, 420, etc is the width of the chain. Commonly refered to as chain size. 428 is wider than 420 and 415 so it will fit a 420 and 415 sprocket. But a 415 sprocket will not fit a 428 chain. And if you manage to bump into a chain size with a letter "H" preceeding the number, it means "heavy duty". 428 and 428H is the same width. The difference is the 428H has a thicker steel plate and heavier. It is better to match up your chain and sprocket sizes to avoid uneven wear. HTH.
X1rCJ
marvymavs said:
428
415
428
415
420
ok sir. thanks a lot for the info, it really helps :idea:
Rjloks
raider125jeigh said:
15 x 42
stock chain....YAMAHA RS100 42t sprocket...
planning to change with 15 x 40 by sunday...
sir i asked the motorcycle parts and accessory shop here in our place, no 40 and 41t. sir can you please give a feedback on 15x42. tnx
