bro its the Rextor CDIjoel said:whats red rextor ?
see this
http://www.yamahat135.com/forum/viewtopic.php?t=468
joel said:^ If u want to increase compression on a stock engine, just remove the cylinder base gasket and apply some threebond. U'll save 0.5mm on the overall cylinder height. U'll get a bump of 20psi nearly.
If u have already done this and still wnat to bump compression further, u can remove metal off the head or the bore and then deepen the valve pockets on the piston to prevent valve bang.
On my engine, I'm running 12.5:1 compression ratio. Stock is 10.4.
Hi Traxxas, if u have removed 1mm on your cylinder block on a 57mm vixion block, then ur new compression is ratio is,traxxas-modifier said:joel said:^ If u want to increase compression on a stock engine, just remove the cylinder base gasket and apply some threebond. U'll save 0.5mm on the overall cylinder height. U'll get a bump of 20psi nearly.
on my stock engine, i shaved off 1mm on my cylinder block
but still the top and bottom gasket is still there.
after 5000km so far no valve piston damage..
engine runs fast!!!!
I love high compression engines!
bro care to show how did you compute the compression ratio
on this thread
http://www.yamahat135.com/forum/viewtopic.php?t=714
No buddy. 3-bond sealer will remain in place as long as u dont remove the block. It will seal really well.charge said:mister joel, does threebond sealer degrades over time?
Yes, you helped me to get valvespring. I can't find any at my placelc-motospeed said:hu? me? have i provided u any aid? haha... well, if u're referring to me then u r welcomed, if not then sorry =) =P >< haha
Hi Hean, yes I use the same white color threebond paste.haen said:@joel : good news to hear then.. i knew this threebond is a gem... u use the white and red box type right ?.. specifically for engine ?
