karl0321
i don't know how to upload video sir.. help me pls.. teach me how to upload videos.. so that i can show everybody how it works..post video so we can see how oil has pumped tru d hose
tanx bro![]()
tanx bro![]()
ive tried that before sir, but lack of space.. it will bumps on the tire, when shocks play..and i tried also to locate the oil cooler between the block and tube of the pipe, and i will relocate the reservoir of the coolant.. but it does not fit.. i also tried to locate the oil cooler above my headlight but i dont like the looksbro why dont you relocate the oil cooler radiator under the water radiator?
in that way fresh air will go directly to it.
.. so my last choice is under my seat.. I just put Mini Fan(from the computer) at the back of the oil cooler and i connect the wire to the wire of the Fan of the Liquid Cooled.. so that if the liquid cooled Fan working the oil cooled fan will work also..Yes Sir, I sacrifice to cut some part of my carburator cover in order to fit the oil cooler.. "Pictures to be uploaded soon"..sir can u put a picture of ur bike with complete fairings??just curious if u did some some "tabas" on ur fairing TIA
nice mods
i bought the oil cooler 2nd hand in the internet..i got it fresh and in good condition..nice mods bro! btw, how much is the total cost of ur oil cooler project? so i can ipon mode now.. hehe.. Tnx!
sir where did u put d hose coming frm d engne?u drilled a hole in ur cylinder head cover?. .the AIS part is d return side ryt? . .so u remove all the ais cntent just to flow the oil?
nice idea too sir.. but for me its better to put the oil return into the camshaft.. because the oil coming from that screw is the oil pump for the camshaft.. so that i put the oil return coming from oil cooler directly to the camshaft..just an idea. .can we put d return on the main oil cap . ?for us to preserve d ais?nd for the clutch assy also to have some addl oil flowing on it to prevent clutch burning. .
yes sir..thanks you..o i see . .so it needs to be on d cylinder head. .nice idea sir
how may kilometers have you already traveled with this setup? do you periodically inspect your cams for "overheating" or is it getting lubricated well???nice idea too sir.. but for me its better to put the oil return into the camshaft.. because the oil coming from that screw is the oil pump for the camshaft.. so that i put the oil return coming from oil cooler directly to the camshaft..![]()
i have not tried traveling that far yet because im still busy at the moment..i always use at short distance but i haven't experienced overheating on my engine yet..and i check the cam it is getting lubricated well.how may kilometers have you already traveled with this setup? do you periodically inspect your cams for "overheating" or is it getting lubricated well???
almost a week sir.. but everyday use.. haven't experienced any problems right now..sir how long hve u been using this mod?
