chiglai .. do you have avail.vixion kits.. hehehe. .how much... one friend is asking..chiglai said:you can ask mang domeng...
LIFE SPAN!! aww my bike would be staying at the grave yard soon if i change those original parts.[/quote:1vls5m0i]yoshimura sniper said:[quote="unlimited express":1vls5m0i]Yes there is. go to TRES HERMANAS in caloocan. the problem is I don't know if its the original vixion kits. I haven't seen a vixion kit yet. hehe
I am having second thoughts of upgrading coz some says the life of the engine will be lesser than the stock block. the stock parts are the best suitable to each other. if we upgrade some parts then there will be an effect like higher comp ratio and others. the benefit is good but the life span of the engine will be shorter because the engine will work harder than before.
I'd like just to make my ride like a show bike.
bro... question, what is the best jet setting for the best result with vixion kit? thnk & ride safe broactually no need to change carb.
stock carb is fine with vixion kit.
just rejet the carb...
the comp rate after changing with vixion block or tuned from me is still within standards.. on service manual minimum is 5.3 kPa, normal at 6 kPa and max at 6.3 kPa.. i've checked it with compression tester and the result is : 6 kPa.. great, isn't it ? will post the pics to prove it..
haen is from indonesia bro.please post in english or much better use PM to himnka port ba motor mu sir??
what is the best size of vixion kit bore 57mm or 61mm??i also plan 2 buy that one.actually no need to change carb.
