Best Sprocket Combi
VChard
tell me about ur riding style and i will try comment on it...
well, i used to travel long distance eveyday, like 50km evryday..just me alone..with my all stock engine sniper 135..so hard for me to reach 120kph..i really need ur suggestions or what wud u recommend setup for me?i mean, just a little upgrade..i was hoping for at least 130-140kph will do good for me..i currently use tire sizes 60/80 front and 70/90 rear..stock sprockets..:confused: and i guess its not suited for me:help:
humanbasic
condition:85 kg rider.
so i suggested u go for:
1.15/41 sprocket or 16/42 combi.use 428 chain set.
2.maintance ur tyre pressure to 32psi or refer to ur tyre wall the max pressure.
3.rejet ur carb mainjet from 105(stock) to 110/115.keep the pilot default.go workshop they can do for you.tune air screw to 11/2turns.
4.change ur coil plug to 150cc motor coil.
try these 4 first,update me later on
VChard
Whew..alright! I'll just give u an update if I already got that setting and tried it..what about the tire sizes?shud I change it to stock sizes?like 70/90 front and 80/90 rear? Thanks much for ur suggestions!
ianghol
WHAT IF SMX:
OPEN CDI
OPEN PIPE
62mm BORE
28MM CARB
R'CAMS
STOCK TIRE FRONT AND REAR
50-55kg RIDER
WHAT WILL BE THE BEST SPROCKET COMBINATION:D
THANK YOU
what's with the PIN sir? i can't understand what does it mean. :D
hahaha..naku pag kinalimutan mo yan d mo na mapapaandar cellphone mo..harharhar
