albert_manio
@suplado010, sir pag pag pinalitan ko na yung cdi kailan pa ako mag rejet?change your cdi..hindi lang 125kph maabot mo..kahit anong combi po gawin mo basta naglimit si cdi walang mangyayare...
no need..as long as your jettings is match with your vixion kit then no need to rejet...@suplado010, sir pag pag pinalitan ko na yung cdi kailan pa ako mag rejet?
stock carb and jettings sir yung akin.. sa pkiramdam ko parng mejo nabi2tin sa gaso.no need..as long as your jettings is match with your vixion kit then no need to rejet...
rejet carb kah poh kasi nakavixion kit kana e...sir ano ba mare2commend mo na jettings? saka sir bkit yung iba naka vixion nagpapalit ng keihin 28..rejet carb kah poh kasi nakavixion kit kana e...
they change carb to maximize the power of vixion kit..for the jettings just ask sir trax because sir admin has more knowledge about sniper...sir ano ba mare2commend mo na jettings? saka sir bkit yung iba naka vixion nagpapalit ng keihin 28..
...it is ok to let the machine to have a high-rev on top crusing?sir humanbasic, i have a adjustable cdi(pitsbike) if you are familiar with it. it has 8 adjustable steps. what step would fit to my mc.? i have 15.42 combi. soon ill change it to 15.41. and sooner i will install carb.suddenly come out,lioke to share....
one of method i use is if i want a acc and dont want to drop the top.i'll set for acc..like 41/15...then.i will advance the cdi setting.if dont have a adjustable cdi,i will put a cooler plug...like u hv ngk 6 and 8...i'll go with 8 as 8 is cooler thn 6(NGK preference only).Then just open the airfuel mixture to just 11/2.
it like when machine hit the high rev,the advancing give an effect like bam,bam,bam bfr reach tdc.(hahahaha).so the advancing ignition compensate 5-10 kmh of top speed la.the feeling comes on highway la....hehe.
if wrong correct me,it fine with me.
in my cdi.. it indicate 1-4 tuning.. 5-8 race modes.. im that familiar to cdi modes. i don't know the meaning of retard or advance.. thank you for helping.. now i know why some of only use dual band. sir but in you opinion it is ok to have an adjustable cdi?usually cdi only have 3 modes:retard,default or advancing.u may either have this kind 4 retard,4 adv or (8adv:u can start try by up 1 step until u reach a set that make ur bike pre-ignite.how to know?when u throtle up,then release,there is explosion like pom,pom,pom.now,u need to back a 1 or 2 step of step.eg u experience denotaion at step5 of cdi,retune to step4 or 3.too advance in setup may cause failure to the plug.)
try use 21/2 mixture turns on carb.
i'm not an expert,just helping....
