Best Sprocket Combi
humanbasic
try to help,if now u still feel the rev on top,just try to rich ur carb mixture,but dont overdo,chek ur plug,the color should be brownish.after u get the best,try to low ur rear sprocket by 1 or 2 teeth,try 1 first.to get the best power of chain,try to minimise the chain length,by doing so,u can minimize power lost from front sprocket to chain,chain to rear sprocket.i mean keep short distance between front and rear sprocket point to point.
set ur tyre pressure to 30 psi.
albert_manio
sir presently i use 15.44 sprocket for my 5 speed lc. it satisfies me because the 5th gear have power (no power drop).i 'am very much concern on my 5th gear because i use my bike every day to go to work and i travel 90-100 km per day and the road was long strech road. but the gas consumption of this combi it was not that good. my 2 liters gas were almost consumed when i get home. i ask some suggestion what combi do i use. they said to use 14. 40 or 41 to get the TS..but if i follow the table ratio of this sprocket combi. 14.40 has the ratio of 2.85 and 15.42 with 2.8 and 14.41 with 2.92 while 15.44 has 2.93 and previously i use 15.42 it has superb acceleration but the 5th came short. which do you think is the good sprocket combi or should i stay on 14 front and play on the rear part of the sprocket? or should i change my cam from vixion cam to stage 2 cam? or rejet the carb again from 120.39 to some jettings? TIA. =)
humanbasic
for ur situation,i'm thinking u r concerning about the fuel.from my understanding,stay with ur 15 44.now just play with ur carb and plug range.3 methods may be used.
1:rejetting ur carb:i assume u r using stock bore.ur jetting is rich my brother....try mj 110 pj 38 air screw 21/2.if the plug reading,te ring is brownish,the air screw is ok.if too lite,just turn 2.
2:rejetting plus cooler plug:by using this setup,u will get a 'lazy feeling' of ur bike,but can reach TS.save fuel but lose some power of acc.by using cooler plug,try using 105 35 set,air screw 2 turns.
3:regap plug and air screw reset pull out ur used plug,using player,u try regap the distance between core with L shape about 0.8 to 1.1 cm....set air screw 21/2 or 3.others keep still the same setup.
this suggestion based on stock exhaust,bore and carb.
try find low cam...
correct me if i'm wrong:help:
albert_manio
yes sir im very much concern about my fuel. because 2 liters for 80-90 klm atleast. (LC 5 speed)
can you give me advice sir
1. here is my setting sir vixion bore, vixion cam, vixion spring, clutch spring, pitsbike rcdi, ngk iridium, stock head
2. my carby jettings is mj 120 and slow jet and pilot jet is the same? (39). from the last time we pull my spark plug my mechanic said it was brownish.
3. standard HGM pipe. (question sir: is big elbow pipe are really needed when replacing our block with the bigger bore?)
4. rear tire of 100/70.
thanks for the info.
humanbasic
the pipe is short or long?better use a long pipe for along run.try use mj110 pj35.but remember...tell ur mechanic that the opinion is yours....dont let him feel that we are teaching him,some manner to respect him.about the elbow,yup.replacing to bigger elbow help to increase the flow rate of exhausted gas and reducing the fluid resistance.but too lean or big pipe size,can kill the back pressure.thus,u need to balance between the gas flow and the backpressure.and that answered ur Q,smaller pipe has more backpressure less flowrate,bigger pressure has less back pressuremore flowrate.
flowrate:adv;fasten time gas exhaust.disadv;loss of power
backpressure;adv;optimum set give optimum output;disadv;may crack ur piston.
but for now onward,just try get the best of ur carb jetting.and keep all first.
correct me if im wrong.
albert_manio
thank you sir for you information. mj 110 pj 35? sir this jettings might be a little bit smaller from my presently jettings i use if im not mistaken. yes sir some say that use long pipe. some said that long pipe are good for touring or long run (i like hispeed pipe for sniper) but unfortunately there is no hispeed pipe for 5 speed lc
i went to my mechanic today to adjust my carb mixture only. he said that that we will change the jettings. main to 25. sir there is solution to loss of power in using big elbow pipe? i have an limited budget sir that is why iam asking question and some suggestion. thank you sir for helping. =)
humanbasic
try do like this,buy a hi speed pipe but change the manifold to 5speed type,what i mean is hi speed+manifold 5 speed.big elbow helps better flow rate,then the velocity of gas back to velocity same as stock when entering the silencer section,only the difference is the flow is smoother at manifold but the velocity reduce back to as stock one when the gas reach the silencer section.thus,the loss on backpressure is not feel in.to overcome the loss power,try rich up the air mixture by manipulating the PJ...just keep the main jet.air screw play between 21/2 to 3.ensure to recheck the plug,it ok if a bit blacky.
recently,ur MJ and PJ for me is both rich,so to cut some fuel usage,better to drop a bit of MJ number.because MJ only play the role after 3/4 to full throttle,but PJ play a role from beginning to the full throttle...if u worry,drop MJ to 115 PJ to 35,air screw 21/2.
albert_manio
manifold is the top part of the pipe? if im not mistaken. sir one question cutting the fuel usage may affect the performance of the bike
humanbasic
to know plug range is differ to one brand to another.e.g.NGK cpr9es is cooler than cpr6es.for bosch and other type the range indicator is differ.yup,leaner
albert_manio
sir question.. what do you suggest.. Port and Polish or Big Valve or should stay stock (cylinder head)? and in cam.. UMA 5.8 lift, CMS 5.8, Faito Low cam advance, what is difference from each other? i'am not into racing i just want racing service.. =).. or do i need to port and polish because of high cc? tIA..
humanbasic
i suggested,just port and polish the exhaust part,leave the intake(oil in).i'm forgot about cam...how to define lift.easily said is uma or CMS is lift more 5.8 degree compared to stock cam.value of stock cam compared with UMA cam yields 5.8 lift difference.e.g:at 180 degree the stock cam displaced 3mm and at 180 degree uma cam displaced(valve opening distance) 8.8mm,thus UMA LIFT 5.8 more than the stock at 180 degree.low cam is the cam displacement is same as the stock cam,BUT the duration of the opening is longer than the stock cam,thus usually low cam promises top end rather than acceleration.the opening allowing the increasing in time for fuel to flow in to combustion chamber,give the system an advancing timing.
haha,i stop here.
port polish is a good practise after a few month of road riding.
if u want a low maintenance bike,use a low cam cause the lift same as stock only the opening duration of valve is longer.
e.g:stock cam can get 140 kmh,low cam can get 150-160 kmh.(our bike meter..haha) BUT taking a time bfr the system switched from idle/stock to advancing.
high cam is powerful at both acc and top end,but u need to recheck the clearence between maximum valve displacement and top piston displacement known as TDC(top dead centre).miscalculate of this cause a phenomena called knocking?the piston head knocked by the valve.if too high compression also can caused leaking.all COST u much.
sometime even the cam is good,but when applied to the machine,the output is fail cause the combination is not synchronised.haha,too many thing to up here.
haha,i stop here.
albert_manio
haha,i stop here.
haha,i stop here.
ok sir i will just port and polish my cylinder head. i read from the forum using high lift cam the piston needs to be valve pocket to avoid the kissing of the valve and the piston. things for the info. i really need to study what different parts to put on my mc.
VChard
if your weight is ranging from 60-70kg 15-40 sprocket combi is a just right. It lessens the load on your engine for the additional weight of your rear tire..:thumbsup:
What if a wiegh ranging 80-85 kg, what possible sprocket combination u suggest?i hav stock engine..stock sprockets 15/39..stock pipe..tire size 70/80 front 70/90 rear..coz so hard to reach 120kph at 4th gear:{
VChard
Can anyone answer me a simple question?whats the differnce btween stock pipe and the open one?wud the top speed matters?or just the acceleration?a newbie here.tanx fellas!:}
humanbasic
80-85 kg=go for 15 41.try use soft compound tire front,medium compound on rear,psi set between 28 front back 29.u can keep the stock pipe,just upgrade the carb to performance carb like pwk28 and similar.for stock engine u top will play around 140-150(or 120-130 kph) depends on setting.just go for carb first....no need for pipe changes.
VChard
woow..sounds good..thanks much for that @humanbasic..do u have any idea if how much wud it cost for upgrading to performance carb as u said?and wat about the stock rear tire size?wud that be alright?or specifically wat sizes of tires u recommend for both?like i weigh 85kg..:help:
humanbasic
tell me about ur riding style and i will try comment on it...
