Best Sprocket Combi
Jiou de Leon
WHAT IF SMX:
OPEN CDI
OPEN PIPE
62mm BORE
28MM CARB
R'CAMS
STOCK TIRE FRONT AND REAR
50-55kg RIDER
WHAT WILL BE THE BEST SPROCKET COMBINATION:D
THANK YOU
hahaha..naku pag kinalimutan mo yan d mo na mapapaandar cellphone mo..harharhar
HAHAHAHA. MAMAW MODS SI IANGHOL!
humanbasic
if that so,try using 14 41....or 42.somehow u need to rev to certain speed to make the final gear alive.if u got some cash,better change the carb.racing carb like uma,oko also ok for the beginning.and other u can keep stock.for sure u can see a different for ur acc and +-10 to 15 kmh for top
xdies01
im currently using 14x39 sprocket on a 62mm bore + 28 keihin carb + cms cams + cms valve spring what are your other recommendations for this setup? ( kinda conservative on fuel consumption especially when i'm out of money :) )
humanbasic
from my observtn....i found that 14;front teeth give a live to top,even feel smoother....but i'm a 16 front fan..hehe.but now on 14...
humanbasic
if u a fuel saver,u can reject ur carb by smalling ur main jet size by -5 or -10,but counter back by using a cdi that can be advanced,or cam that is advanced,simply said,advanced ur combustion system.
e.g;
by stock timing,i'm using 115 mj 32 pj....but when i'm advancing my timing,i can apply 95 or 98 mj 30 or 32 pj....the top can be reached,but u lost some seconds in time where ur system is reaching the advanced timing...this example applicable to ur carb...
but in consideration of big boring...u need to identify ur plug color should be blacky brownish....very critical plug color.
SaladKing
tell me about ur riding style and i will try comment on it...
Good day sir humabasic can you give me a tips on how to improve my sniper mx, my wiegth is 96kg. My smx is all stock except my sprocket 14/42 is this right for my wiegth? And do i need to change my stock cdi to BRT hyper band? And open pipe like leo vince or yy pang shorty? Sorry for bad english..
humanbasic
based on ur weight:
a few tweak u can do is change ur carb to racing carb like uma 28,pwk 28,koso.why i talk about this first because u can see the different,big one by changing ur carb.secondly,upgrade ur coil plug to bigger cc bike coil.then,go for sprocket setup.i have tried out a few things,what i see much different when i change my carb...u can keep using stock exhaust,stock cdi(change if necessary)...
but u can go with carb first,coil plug,sprocket...if u done with this,we can long the talk on others.
another way....people upgrade their cylinder to 60mm,keep stock carb,but still u need to maintain the bigbore,for sure it will be a drain of cash if u not a machinist....
it better for u to describe what u want for ur bike,ur riding style,maintenance capability...on that we all can give u a comment brother
