Jiou de Leon
Anyone here classic user uses 21 or 20T 4th gear? what is your sprocket?
I think nag 17-57 si sir Job kasi ang laki din kaya ng rear niya.it all depends on engine set-up, kay sir admin traxxas nga 17-57 sprocket combi, bat ang tulin pa, kung stock of course 15-39,,, aalma ka pa ba sa approved sprocket combi nang yamaha engineers
how about your cdi? is it RCDI? 15-40, 15-42hello masters. can I know my sprocket combi for my weight? my SniperMX loads are oko carb 30mm, uma black cam stage 2, and cms valve spring & clutch spring. my weight is almost 80kg. but I can only top 130 and nothing more. Im planning to upgrade 62mm bore sooner but I really wanted to enjoy this present loads and top a speed of 140. can I with your sprocket combinations base on my weight and loads? and by the way I have stock rear and front.
my RCDI is pitsbike.. my sprocket combi now is 15/42 but still I only top 130how about your cdi? is it RCDI? 15-40, 15-42
14/42 make sure to use stiffer valve springs..my RCDI is pitsbike.. my sprocket combi now is 15/42 but still I only top 130![]()
sir is your stock piston has a pocket?Need your guys help, I changed temporarily my block from 63mm to stock now,my spec.. brt dual band grey,racing spring valve,cms hi cam,6 spring racing clutch,28mm carb,racing exhaust,tyre 70/90 front & back both same.my currently sprocket is 15-35..my weight around 55-58kg..I feel that my sprocket need to change but I'm not sure to what size. Compared to the big bore,my snipee now is lack of acc and top..anyone can help? Thanks..![]()
maybe your current carb settings did not match on stock bore. IMONeed your guys help, I changed temporarily my block from 63mm to stock now,my spec.. brt dual band grey,racing spring valve,cms hi cam,6 spring racing clutch,28mm carb,racing exhaust,tyre 70/90 front & back both same.my currently sprocket is 15-35..my weight around 55-58kg..I feel that my sprocket need to change but I'm not sure to what size. Compared to the big bore,my snipee now is lack of acc and top..anyone can help? Thanks..![]()
Thanks for opinion JapSpeed..now after I changed back to my stock exhaust n rear sprocket to 36,I managed to reach top easilymaybe your current carb settings did not match on stock bore. IMO
yamaha rs100 sprocketsir anu kapareho ng sniper clasic na sprocket sa rear?? tmx??
salamat e puller po sa magneto??yamaha rs100 sprocket
if you're using stock pipe try 15/42, open pipe 14/40 or 14/42what's the best combi sprocket for 90kg weight with 90/80 rear and 80/80 front tire size. (stock engine) please help. thank you!
