Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
Benedict Hermo
i use, cdi brt hypermax, block 62mm, highcam duration, intake and exhaust flow port and polish. exhaust yy pang.
carb keihin PE 28mm, what is the pilot and mainjet are suitable?
at the end of rev, it dead. help me pllss. ;(
mine using 59mm jvt and 28mm keihin Thailand currently installed 125 MJ and 42 PJ
Benedict Hermo
CMR 61mm steel bore, stage 1 cams.
28mm UMA carb
115- main jet
pilot jet yung stock ng uma, not sure what size..
sir what is the performance of this combination i also planning to buy this carb, currently loaded 59mm block,stage 2 cams and keihin 28mmPE with 125MJ/42PJ, unfortunately not satisfied "may hagok siya" and how bout your gas consumption mine running only 22km/litter obviously matakaw..
thanks sir hope you can share your settings...
Jessie Y
My set up:
62mm steel bore
faito low cams advance
MTRT valve spring
Big valve cyl. head 20/22
BRT rcdi
28mm Keihin carb Taiwan (125mj/40pj)_1.25 turn out AF
Sprocket 15/39
Fuel consumption: 36 km/liter @ kalkal pipe
31 km/liter @ YY Pang
HIWAY MODE
Benedict Hermo
Share ko lang set up ko.
62mm steel bore
MTRT valve spring
BRT rcdi
Sprocket 15/39
Pang HIWAY MODE lang po.
Nice sir, me i know if you are using high flow air filter or your carb open all the way
suplado010
parang anlake po yata ng jettings niyo..baka humahagok poh kasi lunod?
Stockbore
anyone can tell me the proper jet sizes of pe27mm japan?
i use 110 35 and once i rev the throttle, the engines goes wild, i tired from close a/f to fully open. the more i open it the more it screams
AJM
Guys can you recommend jetting for keihin 28mm pe, my loads are faito s4evo cam, vixion vs, brt and clutch spring, hoping for response - tia
AJM
@HKholic can you recommend jettings for my engine set up:
Keihin 28mm pe roundslide
Stock bore and head
Vixion vs
Faito s4evo cams
Clutch spring and brt dual band TIA
