THIS PICTURE SHOW FROM RECTIFIER TO IGNITION
THIS THE PICTURE THAT IM NOT SURE WHICH WIRE WILL YOU REMOVE IF THE GREEN WIRE WILL YOU REMOVE THEN YOUR STOCK BULB WILL NOT ON THAT'S THE WIRE WHAT IM TALKING ABOUT..
WARNING AFTER YOU DONE ALL THIS IT WILL CHANGE THE FOLLOWING:
1. THE BATTERY WILL ALWAYS BOILING, (YOUR DISTILLED WATER WILL FLOW OUT TO YOUR BATTERY CUP IF YOUR BATTERY IS REFILLABLE WITH DISTILLED WATER.)
2. YOUR FUSE WILL ALWAYS MELT NOT TOTALLY MELT BUT IT WILL PARTIALLY MELT (BECAUSE YOU ARE NOW A FAST CHARGING MODE NO MORE LIMIT FOR CHARGE),, FOR ME IF IM NOT USING MY HID I ALWAYS MY PARKLIGHT ON EVEN AT DAY TIME,, REASON: TO AVOID OVERCHARGE MY BATTERY, AND CAUSE BATTERY DAMAGE
3. SINCE OUR MC HAS A TPS (ELETRICAL RELATED) EXPECT OUR IDLING WILL CHANGE.
MAINTENANCE:
1. ALWAYS CHECK THE WATER LEVEL OF YOUR BATTERY BEACAUSE IT DRY FAST DUE TO BOIL.
2. CHECK ALWAYS YOUR FUSE BOX AND FUSE.
FOR ME I USED MY FAST CHARGING MODE OVER 1 YEAR,, ONLY THE FUSE I CONCERN ILL POST IT THE APPEARANCE OF MY FUSE AND FUSE BOX
THIS THE APPEARANCE OF MY FUSE BOX AND FUSE WHEN I WAS IN FAST CHARGING MODE
