LOW CAM ADVANCED
SaM03
sorry to interrupt. so long this thread is on low cam advanced, i just installed this type of cam with normal marking on magneto which is on I. but the sounds are horrible. my piston is 64mm and already pocketed since it came from the shop. and i added a litle slope to avoid the knocking situation. but the sound is to harsh until i'm afraid of starting my engine on. how this is posible? how can i solve it? thankyou
if your timing is in I in the manual guide of lowcam advance you need to put the timing at the H...
SaM03
i am using this Type of Cam.. and i am very satisfied with this cam..
My Current set up is Stock Bore and Stock Stroke Stock bore Shave 1.5mm(Stock gasket is still on para iwas leaking) Piston Valve Packet 2.5mm port and polish head. Faito Lighten Valve, 14/36 sprocket combination... great acceleration and great top end.
ianghol
anu top speed mo papi?..:)
ali imran
currently put on H mark.
my spec, shark HLD racing 64mm bore, std stroke, 4th gear 21t, cdi-brt powermax dualband, keihin pe28 carburator without airbox, 16-33 sprocket, topspeed =170km/h at 8500k rpm. still not satisfied with the topspeed because previous spec which i used std block 54mm with IKK cams. the topspeed also 170km/h at 11000 rpm. but only need longer distant to achieve
ianghol
what if you reach 10,000 rpm at your current set up..maybe you can reach 200kph:D
john-locke
i installed this low cam .
for me not good result . what is very insteresting it is about the start . the motor start very easy with this cam .
only push a few second the starter motor and run immediatly . for me is like uma camshaft .
i don't see more faster or more power . only sweet cam without noise and very powerfull at low rpm but after nothing more . for me camshaft CMS have the best power .
SaM03
The Best Cam so far i have tested... best RPM like a 2stroke :D
(dami nang cams dumaan sakin CMS, YYPANG, UMA, LHK So far the best sakin to ang Lowcam Advance)
ESOJ de GUZMAN JR
how about your stability on reaching 170kph.. i think it wobble.. when i reach 127kph - 120 to gps. it wobbles.. i lowered my front shock about 1/2 inch. semi-flat. but it still wobbles when i reach 120kph +
ace123
sir admin, i tried this kind of valve clearance, im newbie.. 0.08 EX -- 0.06 IN.. s4EVO all stock, do you think, the piston and valves kiss other? please reply,, i just need to know,
theres a big difference
between tik tik tik tik sound on racing cam
and TOK TOK TOK TOK on kissing valves and piston :D
ianghol
nope..i did not reach that speed yet.that was my comment to ali imran..speed i reach is 160 that was when i finished breaking in my 62mm gauge with cbr 150fi..try remove the plastics in your mc and never try a full throttle when heavy wind is opposing your direction this could held to fatal accednt..ride safe bro..;);)
