Status
Not open for further replies.
mry. 522
best valve spring for sniper help?
advantage of
soft valve spring??___________________
medium valve spring??________________
hard valve spring??____________________
help????
suiluj
Some body know how to fix my HID problem. my HID will not Turn On after i used for less than 1 hour. it only happen when i switch off my Engine then when i turn on again my HID will not light. some sound i hear like grounded. day later it will switch on again my HID will light. my battery is in good condition not lowbat.​
ronald031803
you have some lose wire from ballast to bulb
tolitz
Ok lang po b n malagitik ung mc ko after kc nung adjustment ng valve clearance? Anu kaya dahilan bat gnun? Anu mganda gwin para mawala un? Tnx po.
tolitz
Ok lang po b n malagitik ung mc ko after kc nung adjustment ng valve clearance? Anu kaya dahilan bat gnun? Anu mganda gwin para mawala un? All Stock lang po mc ko.
jcm1130
baka hindi tinamaan ng maayus yung right clearance bro.. try mu ibalik dun sa nagadjust.. dapat smooth at tahimik lang ang engine.. pipe lang maingay, hehe..
jcm1130
baka loose connection lang bro, double check your wirings..
Paladin
any suggestion bro?.. ano gamit mo and price niya and where to find origs?..
Honestly speaking I don't know how to whether it's original or not. I use X9 HID, after more than one year it's still working with no problem.
Grounded sound may indicate grounded electricals due to either loose or wrong wiring set up. It's your flasher that is most likely to sound so I suspect grounded wiring. Also check your relay, It may got wet during the rains or when you do car wash.
Whats your cam set up and tappet settings? Tik tik sound depends on the height of your tappet setting.
guitarizta
the same here, it's been 2 weeks since my last tune-up it is only yesterday that i noticed a tik-tik sound in my engine which before i don't notice.
the clearance that I said to the 3s mechanic is .10 and .16 and all my MC is all stock engine parts no modification done.
jamskie
pano po linisan ang piston dun sa may disk brake sa harap po? and ano po ang materials na need?sumasayad kasi ang disk brake. kaya pala umiinit pag nag bya byahe. thanks.
macoolet
spray lng ng wd40 papa...tapos ipit mo ulet disc piga lng ng piga..or kung mtyaga ka,tangalin mo disc,pindutin mo preno,lalabas ng sagad un piston,bugahan mo wd40 tska mo punasan..tpos ibuka mo ulit,ipit mo disc,preno mo ng preno..tpos konting liha dun pala sa lining at hugas ng sabon na panlaba..
febe gienel celebria
papz ask lng po ako.. kanina po pag on ko ng ignition ko hndi umilaw yung neutral indicator at temp.. at hndi ko ma e.start engine ko.. tpos pinatay ko muli ang ignition switch ko at inun ko uli.. at ayun umilaw na at na start ko na.. saan kya ung my maluwag na wiring?? or anu problema??
Status
