coismist
sir limit un... gnun din ung skin nun nakaopen pipe ako...may backfire din minsan sir.
Kung long rides bro specially night dapat alamin mo kung saan yung mga gasoline station hanggat maari dapat di ka mag bitbit nang gas sa MC mo medyo risky kasi yun di natin masasabi kung ano mangyayare delikado, pero kung kailangan talaga dapat dun sa container na pwede ilagay ang gasoline. about kung anong container, sa pagkaka alam ko eh pwede yung mgamga sirs, pwede po ba mag baon ng extra gas during long rides (esp night rides)hazard po ba ito, if ever can we do it in a proper way. veterans kindly comment
59mm jvt plus stock valves=superb..Mga paps may nka try na po ba sa inyo ng jvt 59mm bore sa stock head? Or 59mm bore na lng.. Kamusta ang performance? Ty
Stock carb din ba gamit mo sir? Anong carb gamit mo?59mm jvt plus stock valves=superb..
Uma 28mm sir.pede din stock,rejet ka Lang.Stock carb din ba gamit mo sir? Anong carb gamit mo?
Pag stock carb po ba na rejeted na d naman lean ung result sa spark plug? Sa 28 po ano gamit mong mj and pj? TyUma 28mm sir.pede din stock,rejet ka Lang.
Depende sa jets Kung mag lean..115 at 35..Pag stock carb po ba na rejeted na d naman lean ung result sa spark plug? Sa 28 po ano gamit mong mj and pj? Ty
need ur reply po sana asap kasi punta ako shop aftr lunch..tia bothers!
Bro, if you will follow 3S maintenance guide, every 2k km change oil. Every 4k km change oil filter. As long as your oil viscosity is 50, you have no prob. For me repsol and yamalube will do since I'm changing oil every 1k km. No need for expensive oils.which is best oil mga master? im currently using castrol semi synthetic, okay ba un? or meron mas advisable oil pra sa sniper natin?tsaka gaano kdalas ba mag che change nang oil filter? d ko pa kasi npalitan oil filter ko almost a year na..okey lng ba yun?need ur reply po sana asap kasi punta ako shop aftr lunch..tia bothers!
sir baka typo error masyadong magastos ang maintenance nyo baka bibili ka lang ng suka pag uwi mo change oil agad...Bro, if you will follow 3S maintenance guide, every 2km change oil. Every 4km change oil filter. As long as your oil viscosity is 50, you have no prob. For me repsol and yamalube will do since I'm changing oil every 1km. No need for expensive oils.
paps @john_carlo , kayo po ano po suggestion nyo?sir baka typo error masyadong magastos ang maintenance nyo baka bibili ka lang ng suka pag uwi mo change oil agad...
Post edited...sir baka typo error masyadong magastos ang maintenance nyo baka bibili ka lang ng suka pag uwi mo change oil agad...
