Setting Carb n Jetting
Wan33333
Salam otai2, sy nak tanya sikit, sy dahh settle setting carb, motor takda semput langsung, pakai carb tzm, tp lepas 2 minggu, motor jd semput bila meter 100kmh, bila full throotle semput tu hilang, ap punca ye, mintak tlg ye tq,
Ayep6409
Mgkn jarum je tu try naik kan 1 takuk jarum.
Sepat benua
Assalamualaikum semua..
Terima kasih atas semua ilmu yg diberikan sepanjang sy baca dlm forum ni terutama @man_sate , @Ayep6409, @Amy729 , [USER=17269]@ple5888 utk setting carb
Spec sy skrg
Block : SCK 62.5 mm
Head : std
Valve : std
Teppet: 0.7mm 0.9mm
Cam shaft : cms T2
Spring Valve : OKO
Rod : Koyo
Bearing : koyo
Clutch : Racing
Cdi : BRT smart Click(btdc 29,rpm 14.5) -dulu cdi uma pastu kong.
Coil plug : Uma
Ekzos : std (dulu ekzos uma semput)
Carb : uma 28mm
Intake: std
Mj : 118@115
Pj : 34@34
Takuk jarum : 2
Bukaan angin : 1 1/2 ( filter xpakai tutup filter cap, guna velocity hose SYS)
Plug : coklat
Gear : 1,2,3,4 ok
Spoket size : 15-36
Berat : 85kg
Top speed : 160 km (tegak)
Terima kasih[/USER]
Spec sy skrg
Block : SCK 62.5 mm
Head : std
Valve : std
Teppet: 0.7mm 0.9mm
Cam shaft : cms T2
Spring Valve : OKO
Rod : Koyo
Bearing : koyo
Clutch : Racing
Coil plug : Uma
Carb : uma 28mm
Intake: std
Mj : 118@115
Pj : 34@34
Takuk jarum : 2
Plug : coklat
Gear : 1,2,3,4 ok
Spoket size : 15-36
Berat : 85kg
Terima kasih[/USER]
Wsalam...
Nak tanye sikit.
Exzos standard ori motor ke standard operate?
man_sate
Spec sy skrg
Block : SCK 62.5 mm
Head : std
Valve : std
Teppet: 0.7mm 0.9mm
Cam shaft : cms T2
Spring Valve : OKO
Rod : Koyo
Bearing : koyo
Clutch : Racing
Coil plug : Uma
Carb : uma 28mm
Intake: std
Mj : 118@115
Pj : 34@34
Takuk jarum : 2
Plug : coklat
Gear : 1,2,3,4 ok
Spoket size : 15-36
Berat : 85kg
Terima kasih[/USER]
Sama2
Terbaik..
Amy729
Spec sy skrg
Block : SCK 62.5 mm
Head : std
Valve : std
Teppet: 0.7mm 0.9mm
Cam shaft : cms T2
Spring Valve : OKO
Rod : Koyo
Bearing : koyo
Clutch : Racing
Coil plug : Uma
Carb : uma 28mm
Intake: std
Mj : 118@115
Pj : 34@34
Takuk jarum : 2
Plug : coklat
Gear : 1,2,3,4 ok
Spoket size : 15-36
Berat : 85kg
Terima kasih[/USER]
terbaik bos..kita sama2 belajar..credit lebih utk abg @man_sate sbb die byk bg ilmu kat sini..
tp meter 160kmh badan tegak tu ikot meter lc version brape?
man_sate
Jangan camtu. Hahahaha.
Sama2 share ilmu sini. Credit tok semua orang.
Salam semua..apa effect dye ya kala buat kawah head mcm ni?
Effect die bole low compression terok2 ni.
Ni saye punye skrg. Intake dgn Exhaust
tak dpt amik gambar.
Patut macam ni. Cume bukak sikit lagi.
mrFizi
Salam sejahtera semua.. Sy newbie disini.. Cuma nk tnya otai2 sume.. Sy ada sebiji lc135 v3, sy baru lepas buat top overhaul moto sy (tukar valve minyak 2 btg, grind valve, tukar valve seal, tukar bearing & oilseal waterpump)...tp air radiator hilang..sy check dlm enjin tak ada (xbocor masok dlm enjin)..boleh tlg jelaskan mslh yg terjadi skrg dan jln penyelesaiannya.. Sbb sy dh pening dh..
adamshukor
Cbe cek tangki spare pnuh tak klo pnuh mksud air tndang myb ad bocor pda gasket head.. air tk masok enjin tp duk cmpur dlm blok.. tu pertama kedua myb mase top tu lupa nk masok air atau pn masok air sikit.. cuba tuang lagi pastu try tak payah tutup idop kn motor tgk menymbur kluar tak air nye.. klo mnymbur btol gasket head problem.. klo tkde ok
Ayep6409
Salam semua..nk tnya cikit psl carb ni.sy dh jetting pilot jet paling kecik,jarum ltk paling lean n lubg 2t dh ttp tp asap htm masih ada lg..pakai carb standard xda pulak asap nya.so mcm mana nk selesai kan nya?
Arjuna
Assalamualaikum. Saya masih baru dalam forum. Masalahnya ialah bila saya full throttle pada rpm6000 dan keatas kemudian lepas sedikit throttle enjin jadi cam menarik/sedut/ jerking sekejap. Kemudian saya adjust pada accelerator pump dan skru angin masalah masih ada tapi berkurang. Bukaan skru angin pada 1/3.
Needle jet pada takuk paling atas.
Spec moto:
Block fz
Carb v1
Mainjet 110
Pilotjet 27.5
Cam fz
Spring valve racing
Cdi racing
Ekzos cutting standard
Full bearing
Forged conrod
Gear 4th 21T
Spoket 32-15
Air filter uma racing
superunknown
Salam semua..
Spec sy:
Moto lc135 4speed ES
blok 62mm cardinal
Spring valve cms
head porting and skim
Camshaft cms
Cdi brt
Carb uma 30mm
Saiz mj ngn pj berapa yang sesuai
