BlackSuede
sr is cms stage 2 cam. is plug n play on mx or need to valve pocket?
I don't know the sizes of the valve springs available sir. Just try CMS or vixion valvesprings for starters. If you have extended budget just follow the advice of sir januar to save the cost of labor in opening your engine. ridesafe--preferably what size of valve springs sir???touring will b nice...thank you sir
14-42 sir. or try lower ratios for a start, it will help you reach ts of your stock SMX easily. ridesafe snipers way--newbie here, peeps, guys, Just wana ask few question bout a good combi of sprocket, i have read all ur comments and suggestions but then i still can't decide. mine is a 5 day old smx doing hard break-in.. im planning to change my sprocket.. i am 55-60kg rider, wat sprocket can i put in it to improve acceleration but not to compromise the top speed..
try mu tol 14-45 combit lilipad yan 140kph sa quarter kasu hindi na tataas pa.. hehe ridesafe--Im so Satisfied now using my uma racing cdi. And vixion valve spring tipid mods lng me...can reach 130kph may ibubuga pa kaka testing lng hrap mka tyming. marcus highway mrami pa sasakyan dko ma full throtle
for stock SMX 14-42 is the best combi yet. IMO ridesafe--i just replaced my sprocket combination this morning from 14/38 (stock) to 14/42 and im 70kgs... result was a good acceleration.... but theres a little bit more power on my throttle that the 42 sprocket limit it... maybe 42 is bigger for my kilogram.... i suggest 15/42 or 14/41 combination
bro, wat about vixion valve spring how much, and brt rcdi?14-42 sir. or try lower ratios for a start, it will help you reach ts of your stock SMX easily. ridesafe snipers way--
Here in bacolod BRT dualband cost 3500 up. Vixion Vspring cost 1700 in gen san as I ask sir job last time. But im ussing CMS Vspring now so far so gud. Dualband also kicks hard at TS no limit but watchout for imitation. Ridesafe brothers--bro, wat about vixion valve spring how much, and brt rcdi?
About installing racing cams-Tiktik/takrak sounds is not normal in our lc135 sir. aFAIK. It will damage the valve if that sound is getting noisy, you should get to your mechanic to set your valve clearnce if that sounds start to build up. Vibration is much more entence when you change to stiff vsprings bcoz it'll take you to higher rpm compared to stock vsprings that has a limit. Hope it will help. Share to others and ride safe always.if i change, cams, valve spring, will it be the same with the stock in terms of vibration and even the engine sound, i mean is it still smooth, no vibration and clinging(Takatak") sound of the engine?
For allstock it took me to 120-125kph but it take so much effort hehe. AFAIK 14-42 is not gud for mamaw snipers. Coz it has a very low ratio. (Pampasada ng trisicle) hehe ridesafe--sir what is your ts when using sprocket 14-42????
But still you will injoy the hapines of having a stock engine in that ratio sir coz just a litle part of our population here is in stock set-up.So much effort talaga kelangan sir??hehehe,,,copy sir tnx for the info,
sir, wat about using the 15, 42 isn't it a lil bit faster than the 14,42 in stock engine and tires?But still you will injoy the hapines of having a stock engine in that ratio sir coz just a litle part of our population here is in stock set-up.![]()
15-42 is surely has a higher ratio than 14-42 so it issir, wat about using the 15, 42 isn't it a lil bit faster than the 14,42 in stock engine and tires?
But consider you are allstock, Compared to sir jap with protec haha Ridesafepaps mas mabilis mng makuha top speed mo sa 14-42... pero if you want miracle top speed mg 15-42 ka... bakit miracle? kasi minsan mas mataas pa ang top speed mo sa inyong inaakala... hehe... especially same direction ka sa hangin... IMOsir, wat about using the 15, 42 isn't it a lil bit faster than the 14,42 in stock engine and tires?
