T135 Sprocket Table Combination Part 2
boytiempoh
good day to all.
what do you think is a good sprocket combi for my sniper mx?
I noticed that in the stock combi which is 14-38 the 5th gear didn't do well.
I'm currently using 13-40 now.
so far I'm fine with the performance but I can only reach about 110-115.
i really don't know is my sprocket combi is wrong or the road is just bad.
Paladin
good day to all.
Try to change the engine sprocket to 14. IMO, 13 is too small.
PLDC
for me what is the best sprocket??
90/80 front and rear i want more acc. and some power....
sprocket now 14 - 38
Paladin
I just changed Sprocket set from 14-38 420 into 15-40 428. A little bit decreased in acceleration but with a visible increase in top end.
aklan
Continuation from part I
Heres a table of sprocket combination for reference.
the stock gear ratio is 2.6 (in bold)
the color green gear ratio are high speed sprocket combination.
the lower the gear ratio, the more high speed (top speed, less acceleration)
the color red are low speed sprocket combination.
the higher the gear ratio the more low speed. (good acceleration, less speed)
Front teeth | Rear teeth= Gear Ratio
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
15 39 = 2.6 Stock gear ratio
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
so if you want more top speed than stock settings
use 14t front and 36t rear
or 16t front and 41t rear
if you want more acceleration
use 13t front and 34t rear
or 16t front and 42t rear
BIGGER TIRES (100/80 and up): use color red
SMALLER TIRES (80/80 and below): use color green
sir thank you for your advice
i use 70 in front 80 on rear soo
i should change my sprocket 13t front and 34t rear ?
