T135 Sprocket Table Combination Part 2
aziz
how to get top speed at 190km/h above at 1km?
is there any suggestion how to get a better top speed and pickup?
is it 16/39 better? or 15/35? any suggestion? help me..
carlhpac
i'm confused help plssss....
Seniors pls help me... my sprocket combination is 15 front and 38 rear using 420 chain.. i want to modify my t135 into circuit type tune motorcycle
what is the best tire size in dunlop tt900 to have acceleration and top speed with 15/38 combination?
modification:
-stock engine
-rextor cdi
-iridium spark plug and racing coil
-k and n filter
-dbs pipe
:wink: :wink: :wink:
Za8
Hi guys wanna ask u guys for help...
here goes!!
1st gear-0 - 20kmh
2nd gear-20 - 40kmh
3rd gear-40 - 60kmh
4th gear-60 - 110 120kmh...
jus frm the chart for the speed my speed is way below par...im currently using 15 front and 42 rear...can i noe wats e prob here...my fren told me to change to 42 for betta pick up but i dun c e diff frm the stock 39T...
Can i noe wat is the problem here???
chiglai
it really depends on the set up.. tyres, riders weight.. etc..
changing to bigger sprocket wont get a good topspeed..
but better acceleration..
badboy5474
hi every1.. i am new here... all of u are giving gud tips for all... thank u...
plz help me with my bike... my bike is in stock condition for the engine part. i am using 80/90 tyres..
last time with my standard sporkets i can go to 155kph.. (LC gouge)
after i change my sporkets to 15f and 37r with 415 chain....
i can get 125kph in 3rd gear.... but the top speed is juz slighty more than 130kph in my 4rd gear ...
the rpm is not enough i guess :roll:
can u guys advice me which sporket to use... i want more top speed....
plz advice... thank u
chiglai
how about trying going back to stock combination 15-39-415?
or go for 15-38-415
Za8
Hi guys wanna ask u guys wat is the best size for top speed??
thanks!!!! I want smoothes in riding..
And im gonna buy a racing CDI soon..
tatsing85
depends on ur bike setting.... tire size and body wt..... but bro i recomend u try drop 2 15-38..... try first.... if not to liking then drop 2 15-37..... no matter how low or how high ur sproket ur bike tend to stress... the lower u go at 4th gear low rpm..... tha higher sproket size u go u tend to over rev ur bike..... Za8 stay which part of spore??
thrasher
hey guys i intend to change my sprockets to 15/36. thats abt 2.4 revs for the rear. so any opinion whether this is advisable? i'm currently using 15/38 and my top speed is 140.
tatsing85
using 15/36 428 chain.... if u r using stock cdi stock carb not recomended..... u stress out ur bike till u get to optimum speed.... heres my setting.... uma racing carb big bore redbull cdi relayed cdi and im using 15/37.... see thrasher u have to play around with the sproket size till u get it to your liking.... too big sprocket may result in excessive reving during top gear.... coz bike too light..... too small and u stress ur bike.... furthermore spore road u need more to pick up then to top speed..... if u noe wat i mean.... ( F*cking taxi drivers)
tatsing85
kelisa6009 said:
if i change to 15 front and 38 rear...do i need to change the stock chain?
kelisha its recomended that u change chains also when ur sprocket is change.... wat size chain is up to u...... to me 415 not lasting than 428.... just my 2 cents
kelisa6009
bro thanks for the advice...got one more advice i need from sifu...
my current top speed is 140km/h..that is max for my stock bike...i plan to change spocket to get more top speed...what is the best combination?
thanks
kelisha...try 15-39 with 415 chain...try find the good brands....
d.i.d or sss....u should get 160+...it depends on ur weight also...
kelisa6009
our stock is already 15 front and 39 rear right?
my weight is less then 60kg....but still cannot reach 150....i try once reaching 150 while going down hill...the engine scream like going to blow....is this normal? by the way...i bought the clutch version 135LC
yes...with ur weight..i think u should try 15-38 with ur 428 chain 1st...if u notice tht u can go a bit fast than ur stock chain..try 15-38 415 chain...u will love it...peace...
anyone guys...plz correct if im wrong...
kelisa6009
thanks for the advice...will try this weekend...
