the modification of my 4year old lc135
macoolet
e gearings?..iba kasi dumulo ang naka big valves din..talo mo ko 220 lang ako e hahaha di ka naiilang dun sa manipis na gulong with rimset?
halos parehos lang kami ng engine specs bro big valve lang pinag kaiba namin, bigat yung motor nya bro pero si admin magaan, ako bro im 270 lbs. bigatin
jimpie
hindi koso digital almost same speed with GPS
paps share your specs
ako specs. ng MC
*stock head PnP
*BRT HYPERBAND
*Ultimate Racing Ignition coil
*Faito Block 60mm
*Stock Carb Modify MJ PilotJet 105 and 22.5 Disable Chock
*Clutch Spring CRG
*Camshaft Faito Turbo
*Valve Spring Vixion
*Pipe AHM Gold
*SP Iridium Iu27
*Sprocket Combi SSS 15/39 415
*Stock Air Filter
SPEED RACER
hindi naman bro, noon gamit 45/90 front 60/90 rear kaso lang madali ma flat, yung kang traxx bro at kay bro rowan 4th gear 21t ang nag bigay ng dulo, kahit naka big valve siya pero hindi sya naka 4th gear wala sya dulo kahit gumamit pa sya malaki ng sprocket combi, sa totoo lang na bibigayan kami ne bro rowan ng mga tips...
SPEED RACER
ako specs. ng MC
*stock head PnP
*BRT HYPERBAND
*Faito Block 60mm
*Clutch Spring CRG
*Pipe AHM Gold
*SP Iridium Iu27
*Stock Air Filter
kulang mo bro carbs at saka 4th gear nalang mamaw yung modes mo...
macoolet
naka stroker pin ako paps :confused:
macoolet
vixion kit
pin 1.5
28 mm keihin round
yy pang valve spring and cam
crg c. spring
brt dual band
ahm gold 90/80
fdr mp76 front and rear tires
stock gearing,coil,NGK sp ordinary,clutch lining
15/44
SPEED RACER
vixion kit
pin 1.5
28 mm keihin round
crg c. spring
brt dual band
ahm gold 90/80
15/44
hindi ba galit yung engine mo sa 15/44
nag add ka spacer bro, o wala..
