Tuneboss Sniper Mx 150
jariusxd
Good Day Sir.
I purchased my tuneboss ECU for Sniper 150.
As for mapping, is uma racing pipe consider as free flow or as stock?
as for fuel adjustment and spark adjustment any help with that?
ride safe
20vturbo
Hi,tune boss user here.Uma's is not considered standard.
As for you second question, what sort of mapping do you want?
mxking035
Hi bro , i just update my bike to 62mm block 22/24 head ttb32mm 160cc Injector and try all the map download but still fuel not stable.
My location here don't any dyno service. Any solution?
what is your camshaft and sparkplug?
What kind of piston you have? Dome or flat?
mxking035
I using map 174 , engine just like normal.
But the fuel not stable. Rpm high low high low
Try using my Map (edited for 160cc), can you give me you email?
I'm using 180cc Injector, 32mmTB, 20/22 Head, SpecV 6.5 cam, 62mm lightened
mxking035
I upload file and change the filename extension from .txt o .zip
Extract it to File Manager>Tuneboss>Tables
Open Tuneboss Manager and load the map, try this map if it works
GUKIMEN
any recommended map for my set im using cms t2 cams, jvt valve spring ,uma pipe and high flow air filter the rest stock
mxking035
map83, edit some afr at low rpm and 6-7k rpm, add small fuel because that map is hot for low rpm
