Tuneboss Sniper Mx 150
gdeezzyy
cms t2 5.8 is safe, even for jvt fulldome 57mm,
cms 5.8 and specv 5.8 is not same, different profile, I have not yet tried specv 5.8,
I just tried CMS T2 and SpecV 6.5
sir san po pwede mka avail ng cms t2 na cams and semi dome 57mm piston? thanks
Dhecks
You can use Map 49
Sir need help.. my mx150 wont go over7500 rpm but set the limit to 11500.. my set is 57 dome piston 22/20 head tb 32.. it ends to cut off like limiter on 7500 rpm dont know if reach or lean.. thanks in advance..
Wamonoseko
Can you clarify sir what moods that makes your rpm limited.
amirulmab
hi bro need help here. i use fz150 model 2014, i change my blok ( arata 62mm) and cam ( high cam arata).
any suggestions for fuel adjustment? because when i release throttle, it turn off
JapSpeed
adjust throttle body idle. makt it higher than standard setting.
