GUKIMEN
oh the table can be edited?Try this, change extention .txt to .zip, and extact to Tuneboss>Table
yes you can with tuneboss manager pro, I edited map83 for youoh the table can be edited?
oh the pro version gonna try your edited map tom. sir hehe tnx for the effort!yes you can with tuneboss manager pro, I edited map83 for you
npoh the pro version gonna try your edited map tom. sir hehe tnx for the effort!im using the ordinary version of manager thats why im wondering how come you can edit downloadable maps hehe
sir tnx for the map i've noticed better response in throttle it is dyno tuned?
no, I just estimated the fuel base on my experience on my old setup, I just made it the time i send it to you, actually i never edited any map during may old setup, using cms t2 and open pipe.sir tnx for the map i've noticed better response in throttle it is dyno tuned?
ahhhh so what is your new set up now?no, I just estimated the fuel base on my experience on my old setup, I just made it the time i send it to you, actually i never edited any map during may old setup, using cms t2 and open pipe.
tunebossahhhh so what is your new set up now?
nice set 180cc?tuneboss
62mm semi-dome lightened piston
32mm Throttle Body
12holes Injector
22/20 bigvalve with headworks
6.5 specV camshaft
Uma Valve Spring
Adjustable Timing Gear
Manual tensioner
Faito Coil (before is coil from multicab for 1yr+)
Faito Crankshaft Bearing
Denso Iridium (I have 3 different sparkplug, depends on purpose)
yes or 177ccnice set 180cc?
niceyes or 177cc
if you plan to use 62mm+cms t2, it is not advisable for me, it will have over compression or need 10/12 holes injector to deal with overheatnice
i'm using SWR also, 32mmHi bro do u know swr ttb how to adjust?
what do you mean? power results? or map settings?Any results for add fuel tq bro
Rpm high low adjust ttb and add fuelwhat do you mean? power results? or map settings?
what is your setup?
nice suggestion sir but i'll go for super stock set up for touring use i'm not more on racing heheif you plan to use 62mm+cms t2, it is not advisable for me, it will have over compression or need 10/12 holes injector to deal with overheat
in my experience,
62mm + cms t2 + stock injector + w/0 airfilter - hard to tune, overheat easier if not well tuned, 14/42 or higher
62mm + cms t2 + 12 injector - cold engine, better with mx135 sparkplug to deal with overgas and better than 1st, 14/42 or higher
62mm + cms t2 + 12 injector + 32mm TB - easier to tune, can use any sparkplug to tune, better with stock SP, 15/42 or 15/43
62mm + cms t2 + 12 injector + 32mm TB+ 20/22 head - better with shaved block 1.2mm no base gasket, stock SP, 15/42 or 15/43
62mm + specV 6.5 + 12 injector + 32mm TB + 20/22 head + timing gear + simota - I like it, very easy to tune, easy e-start, 15/42 or 15/43
its better to use racing coil like multicab coil or Faito FI coil
you can add 57mm dome piston, simota airfilter, 32mm throttle body, faito coil, hyperclutch, headworksnice suggestion sir but i'll go for super stock set up for touring use i'm not more on racing hehe
Hi bro dyno tuning good or not?you can add 57mm dome piston, simota airfilter, 32mm throttle body, faito coil, hyperclutch, headworks
