actually ginawa namin isa lang yung binarahan yung sa baba ng radiator yung bago dumating sa maliit na square ba black box. Kay traxx 3 yata yung binarahan, kami isa lang pero effective nawala yung backfire, worry lang ako baka may bad effect.makibaohto said:gawin mo yung simple mode about ais plugging,hanapin mo sa tips ang tricks..
try to increase the amount of air going into your engine by adjusting your air screw. the camshaft allows more fuel entering the combustion chamber so there is a chance that not all fuel were burned. if this will not resolve or eliminate the backfire, try to use smaller main jet.acidrain said:up ko lang yung question ko;
before wala akong backfire, after ma install ng cam, madalas na ang backfire ko, stock carb wala sa tono (hindi maitono, plan to get 26mm).
Meron bang kinalaman ang carb at cam sa pag backfire?
the electric starter would not be able to crank your engine with that setup but you could use the kick starter simultaneously with your electric starter.sunmoon said:tan0ng ko lang mga master vixi0n kit at kawahara k1 kaya ng electric starter?
ok, i will try to add more air, currently setting 2 turnsRolly said:try to increase the amount of air going into your engine by adjusting your air screw. the camshaft allows more fuel entering the combustion chamber so there is a chance that not all fuel were burned. if this will not resolve or eliminate the backfire, try to use smaller main jet.acidrain said:up ko lang yung question ko;
present..!! kaso k2 gamit ko eh at naka squishband narin kasi yung aken at yung piston ko nung dumating saken naka valve pocket narin gawa ni haen.botsokbriones said:may nakasubok na ba ng kwahara k1 cams and yung lower cylinder gasket removed?
hindi kaya tutukod yung valves? need na ba ang valve pockets?
help po mga masters..
Bistado na ang may mamaw modsUndah-Bone said:present..!! kaso k2 gamit ko eh at naka squishband narin kasi yung aken at yung piston ko nung dumating saken naka valve pocket narin gawa ni haen.botsokbriones said:may nakasubok na ba ng kwahara k1 cams and yung lower cylinder gasket removed?
Bistado na ang may mamaw modslml_sete said:[quote="Undah-Bone":3p1j4uvp]present..!! kaso k2 gamit ko eh at naka squishband narin kasi yung aken at yung piston ko nung dumating saken naka valve pocket narin gawa ni haen.botsokbriones said:may nakasubok na ba ng kwahara k1 cams and yung lower cylinder gasket removed?
yang bang k2 mo papi naka custom grind pa?tska anong carburador gamit mo?thanksUndah-Bone said:present..!! kaso k2 gamit ko eh at naka squishband narin kasi yung aken at yung piston ko nung dumating saken naka valve pocket narin gawa ni haen.botsokbriones said:may nakasubok na ba ng kwahara k1 cams and yung lower cylinder gasket removed?
di ko lang alam fafs.. basta kung ano yung kasama dun sa tuned package ni haen na cams yun na yun walang ginalaw.Chill4305 said:yang bang k2 mo papi naka custom grind pa?tska anong carburador gamit mo?thanksUndah-Bone said:present..!! kaso k2 gamit ko eh at naka squishband narin kasi yung aken at yung piston ko nung dumating saken naka valve pocket narin gawa ni haen.botsokbriones said:may nakasubok na ba ng kwahara k1 cams and yung lower cylinder gasket removed?
di ko lang alam fafs.. basta kung ano yung kasama dun sa tuned package ni haen na cams yun na yun walang ginalaw.Undah-Bone said:yang bang k2 mo papi naka custom grind pa?tska anong carburador gamit mo?thanksChill4305 said:[quote="Undah-Bone":ufybkmsl]present..!! kaso k2 gamit ko eh at naka squishband narin kasi yung aken at yung piston ko nung dumating saken naka valve pocket narin gawa ni haen.botsokbriones said:may nakasubok na ba ng kwahara k1 cams and yung lower cylinder gasket removed?
di ko lang alam fafs.. basta kung ano yung kasama dun sa tuned package ni haen na cams yun na yun walang ginalaw.Fiat_01 said:[quote="Undah-Bone":1zfrjt71]yang bang k2 mo papi naka custom grind pa?tska anong carburador gamit mo?thanksChill4305 said:[quote="Undah-Bone":1zfrjt71]present..!! kaso k2 gamit ko eh at naka squishband narin kasi yung aken at yung piston ko nung dumating saken naka valve pocket narin gawa ni haen.botsokbriones said:may nakasubok na ba ng kwahara k1 cams and yung lower cylinder gasket removed?
