kawahara cam s1/ vixion valve spring, share your experience
acidrain
up ko lang yung question ko;
before wala akong backfire, after ma install ng cam, madalas na ang backfire ko, stock carb wala sa tono (hindi maitono, plan to get 26mm).
Meron bang kinalaman ang carb at cam sa pag backfire?
acidrain
makibaohto said:
gawin mo yung simple mode about ais plugging,hanapin mo sa tips ang tricks..
actually ginawa namin isa lang yung binarahan yung sa baba ng radiator yung bago dumating sa maliit na square ba black box. Kay traxx 3 yata yung binarahan, kami isa lang pero effective nawala yung backfire, worry lang ako baka may bad effect.
Trial n error din ang plano ko don before, kasi nung isinara namin saka lumabas yung warning, pero ngayun kahit walang bara nag wa warning pa rin hehe
Rolly
try to increase the amount of air going into your engine by adjusting your air screw. the camshaft allows more fuel entering the combustion chamber so there is a chance that not all fuel were burned. if this will not resolve or eliminate the backfire, try to use smaller main jet.
Rolly
sunmoon said:
tan0ng ko lang mga master vixi0n kit at kawahara k1 kaya ng electric starter?
the electric starter would not be able to crank your engine with that setup but you could use the kick starter simultaneously with your electric starter.
botsok
may nakasubok na ba ng kwahara k1 cams and yung lower cylinder gasket removed?
hindi kaya tutukod yung valves? need na ba ang valve pockets?
help po mga masters..
acidrain
ok, i will try to add more air, currently setting 2 turns
Undah-Bone
present..!! kaso k2 gamit ko eh at naka squishband narin kasi yung aken at yung piston ko nung dumating saken naka valve pocket narin gawa ni haen.
rr117-sacker41
ako naka vixion kit at kitty rcams electric starter p din gamit ko. sa mga magpplit ng cams ipavalve pocket nyo na piston nyo mahirap matukudan sabog pa makina nyo.
rr117-sacker41
meron pa secret para sa t135 gamit ko ngayon cdi ng mio super lakas walang sawa sa dulo.
sa mga gumagamit ng cdi ng mio sa t135 share din nman kayo.
lml_sete
Bistado na ang may mamaw mods :p
Ano ba yang valve pocket na tinatawag mga bros?
Undah-Bone
lml_sete said:
[quote="Undah-Bone":3p1j4uvp]
Ano ba yang valve pocket na tinatawag mga bros?[/quote:3p1j4uvp]
mas mamaw parin yung mga naka 61mm.. 57mm lang ako eh. :wink:
eto yung valve pocket fafs. sample pics from xr200 piston.
tignan mo mabuti yung piston may uka diba? yan yung tinatawag na valve pocket para di umuntog yung valves sa piston naten.
botsok
need ko pa kaya yan?
stock bore and piston ang sakin,. stock valves, yun nga lang, wala nako lower cylnder gasket..
di ba mababawasan ang compression mo kapag may valve pocket?
Chill4305
yang bang k2 mo papi naka custom grind pa?tska anong carburador gamit mo?thanks
Undah-Bone
di ko lang alam fafs.. basta kung ano yung kasama dun sa tuned package ni haen na cams yun na yun walang ginalaw.
keihin Thailand PE26 ang gamit ko fafs.
Fiat_01
Undah-Bone said:
Chill4305 said:
[quote="Undah-Bone":ufybkmsl]
keihin Thailand PE26 ang gamit ko fafs.[/quote:ufybkmsl]
- bigatin tlga oh..galing pa ke haen..niceeeeeeeeee..
Undah-Bone
Fiat_01 said:
[quote="Undah-Bone":1zfrjt71]
keihin Thailand PE26 ang gamit ko fafs.[/quote:1zfrjt71]
- bigatin tlga oh..galing pa ke haen..niceeeeeeeeee..[/quote:1zfrjt71]
mas bigtime ka parin mama shai at yung mga naka 61mm dyan. hehe.
