thanks bro, wala kasing counter part sa polini dati at metrakit meron man wala pa sa pinas , and stage6 late na nag switch na ang mga 2 stroke to 4 stroke due to expensive parts and mostly came from europe, yes its a bit expensive in one unit of about 2ok someting cdi rotor and ignition coil, and the next one was my pipe mhr team 2004 , igot this thing in access plus in p tuason,This part is the most expensive, dream of every 2 stroke scooter modifier.
you are late bro nabenta ko na ang mga ito sa tropa ko dito sa ne, i got from malaysia sa tropa ko , mahina ang piston nya to be honest but the best thing is yun bore liner nya maganda finish even this is steel bore , kitang ko yun patern ng guhit nya para sa langis which is more important when comes to steel bore, but the best way to use this kit changing it to pin15 so marami na kong makukunan ng 65mm piston like in the pix with 4 deep valve pocket for high lift camshaft,wow master ikaw n nga... master pabulong nmn san mo naiskor, 65 mo, mukang like q rin,, gsto q sna mas malaki pa n bore pero saka nlng dapat mauuna ang master bago ang apprentise diba.. la kasi aq mahanap master baka my alam ka? planing kasi aq, meron na kasi aq radiator ng cbr.. bore nlng ala, wehehe
order ka na lang sa motomalaya he he he kaya mo yun ikaw pa....
gnun b bro, salamat,you are late bro nabenta ko na ang mga ito sa tropa ko dito sa ne, i got from malaysia sa tropa ko , mahina ang piston nya to be honest but the best thing is yun bore liner nya maganda finish even this is steel bore , kitang ko yun patern ng guhit nya para sa langis which is more important when comes to steel bore, but the best way to use this kit changing it to pin15 so marami na kong makukunan ng 65mm piston like in the pix with 4 deep valve pocket for high lift camshaft,order ka na lang sa motomalaya he he he kaya mo yun ikaw pa....
oi abangers oh, my planu, wahaha peace bropapa axon any update sa 65mm?
hi bro im using M8x1.25 x 195mm long std. stud bolt until now , but you can use normal stud if you're just stroker with stock bore around 150cc, spacer i used 4.5 to 5mm alloy base gasket, during that time i can't find 5mm 1pc of gasket only 1mm to 3mm so i just used 2+3mm,What head bolts or studs are you using with this? A cylinder spacer for the longer stroke will use up threads on standard head bolts. I ask because I have decided to build a stroker motor, but am thinking about the bolts.![]()
keep goin bro.. looks holding and firing a gun i'm gun fanatic too,
even your username pistol brand he he he , i owned both beretta92 fs and paraX1640 limited,rowan and vhadz, musta medyo matagal akong di nakaka onlie andito na ulit ako sa labas for my work he he he so hinto muna si snipee garahe na muna sa kamalig kasama ng mga palay at bigas he he henabitin ang upgarde ko i need to leave ugently.....call of duty ika nga he he he
keep safe guys..![]()
thanks bro rowan, nahati nga time ko for both my hobbies shooting range , bike at tsikot, pa summer na dito kaya makakagala naman ako he he he yes why not kung mi mga query ang tropa 1 mo. na rin ako mahigit dito at first few week talagang bz , regarding sa special tools no problem, kahit paano mi naitulong ako not only in this thread but in kind he he he .....pero my up coming akong project adjustable cam gear, sana mag ka time....pinagsabay mo kc papa axon ang tsikot mods mo eh, dbale family first . dont worry d2 lng kmi mga tropapips ng t135. thanks sa blog mo. in behalf mof motoflash thanks din sa machinery tools mo, andaming nging mamaw dahil doon.
next bka may grasya nman taga mindanao sau na special tools hehehehe.
khit sa work ka buhayin mo rin e2 paminsanminsan dami rin natoto d2.
keepsafe sa work
ahem!! ahem!! mukang di ata aq napasali jan ah.. hmmmmmmp!!pinagsabay mo kc papa axon ang tsikot mods mo eh, dbale family first . dont worry d2 lng kmi mga tropapips ng t135. thanks sa blog mo. in behalf mof motoflash thanks din sa machinery tools mo, andaming nging mamaw dahil doon.
keepsafe sa work
master axon,, ok lng yan kahit minsan minsa ka lng bumibisita s blog mo, ang mga nakapost dito pang habang buhay n tatak s bawat nilalang khit pilontropo at pilosopo d aangal at walang masasabi dito, detalyado eto,, uve made ur signature ika nga,,pinagsabay mo kc papa axon ang tsikot mods mo eh, dbale family first . dont worry d2 lng kmi mga tropapips ng t135. thanks sa blog mo. in behalf mof motoflash thanks din sa machinery tools mo, andaming nging mamaw dahil doon.
keepsafe sa work
ahem!! ahem!! mukang di ata aq napasali jan ah.. hmmmmmmp!!![]()
