my simple and DIY modes fr. NE
axon
This part is the most expensive, dream of every 2 stroke scooter modifier.
thanks bro, wala kasing counter part sa polini dati at metrakit meron man wala pa sa pinas , and stage6 late na nag switch na ang mga 2 stroke to 4 stroke due to expensive parts and mostly came from europe, yes its a bit expensive in one unit of about 2ok someting cdi rotor and ignition coil, and the next one was my pipe mhr team 2004 , igot this thing in access plus in p tuason,
axon
wow master ikaw n nga... master pabulong nmn san mo naiskor, 65 mo, mukang like q rin,, gsto q sna mas malaki pa n bore pero saka nlng dapat mauuna ang master bago ang apprentise diba.. la kasi aq mahanap master baka my alam ka? planing kasi aq, meron na kasi aq radiator ng cbr.. bore nlng ala, wehehe
you are late bro nabenta ko na ang mga ito sa tropa ko dito sa ne, i got from malaysia sa tropa ko , mahina ang piston nya to be honest but the best thing is yun bore liner nya maganda finish even this is steel bore , kitang ko yun patern ng guhit nya para sa langis which is more important when comes to steel bore, but the best way to use this kit changing it to pin15 so marami na kong makukunan ng 65mm piston like in the pix with 4 deep valve pocket for high lift camshaft, ;) order ka na lang sa motomalaya he he he kaya mo yun ikaw pa....:cool:
axon
Very informative thread sir. Has me thinking a lot. One of which is building a "squared" engine as opposed to under or oversquared and how it effects power delivery. After reading through, I'm curious if your project has touched the pavement yet. Really interested in the outcome of your work. :thumbsup:[/quote]
welcome and thanks bro, no not yet i'm still developing it in ignition system (advance and retard ignition ) and making my own adjustable cam sprocket, like what we got in race car engine, a reason thats push me to fabricate my own , and i found out its not imposible there's enough room, just imagine removing decom set, then you'll see leaving the nut that drive and lock water pump and cam:thumbsup:
HKholic
Thanks Axon, for the welcome and the reply. You obviously have great patience and attention to detail. Should be one hell of a piece of work!
blackknightrealms
i really enjoy this part of this forum.nice information feedback and side stories.interested to know the outcome...hope more info on some area to look at.tips and trick and guides.looking forward on next post!
vhadz
gnun b bro, salamat,
motomalaya? ano aq big time? wehehe
katagal din magdating kasi,, cge2 master pm nlng po kita f ever jejeje,
HKholic
What head bolts or studs are you using with this? A cylinder spacer for the longer stroke will use up threads on standard head bolts. I ask because I have decided to build a stroker motor, but am thinking about the bolts.:help:
axon
hi bro im using M8x1.25 x 195mm long std. stud bolt until now , but you can use normal stud if you're just stroker with stock bore around 150cc, spacer i used 4.5 to 5mm alloy base gasket, during that time i can't find 5mm 1pc of gasket only 1mm to 3mm so i just used 2+3mm, :) keep goin bro.. looks holding and firing a gun i'm gun fanatic too,:) even your username pistol brand he he he , i owned both beretta92 fs and paraX1640 limited,
welcome sa thread bro,
axon
rowan and vhadz, musta medyo matagal akong di nakaka onlie andito na ulit ako sa labas for my work he he he so hinto muna si snipee garahe na muna sa kamalig kasama ng mga palay at bigas he he he :) nabitin ang upgarde ko i need to leave ugently.....call of duty ika nga he he he :)
keep safe guys..;)
rowan
keep safe guys..;)
pinagsabay mo kc papa axon ang tsikot mods mo eh, dbale family first . dont worry d2 lng kmi mga tropapips ng t135. thanks sa blog mo. in behalf mof motoflash thanks din sa machinery tools mo, andaming nging mamaw dahil doon. :dance:
next bka may grasya nman taga mindanao sau na special tools hehehehe.
khit sa work ka buhayin mo rin e2 paminsanminsan dami rin natoto d2.
keepsafe sa work
axon
keepsafe sa work
thanks bro rowan, nahati nga time ko for both my hobbies shooting range , bike at tsikot, pa summer na dito kaya makakagala naman ako he he he yes why not kung mi mga query ang tropa 1 mo. na rin ako mahigit dito at first few week talagang bz , regarding sa special tools no problem, kahit paano mi naitulong ako not only in this thread but in kind he he he .....pero my up coming akong project adjustable cam gear, sana mag ka time....:)
X1rCJ
tagal mong nawala bro :) sarap nga magbasa sa blog mo e, dami ko nalalaman at natutunan. like rowan said, andaming natututo dito lalo na yung mga takot maghawa ng sariling nilang bike hehe keep on coming :thumbsup: at syempre like bro rowan said again, dito lang ang T135 fam! keep safe!
vhadz
keepsafe sa work
ahem!! ahem!! mukang di ata aq napasali jan ah.. hmmmmmmp!! :censored::dance:
vhadz
keepsafe sa work
master axon,, ok lng yan kahit minsan minsa ka lng bumibisita s blog mo, ang mga nakapost dito pang habang buhay n tatak s bawat nilalang khit pilontropo at pilosopo d aangal at walang masasabi dito, detalyado eto,, uve made ur signature ika nga,,
family comes first b4 anything else, hobbies comes 2nd, wehe hirap enlissh, by da way, any way, hi-ways, good luck master axon, god bless, :thumbsup:
