Gerry Jaloro
14-42 is good for stock bore...Hi mga papa...what is the best sprocket combi of this set
UMA SUPERHEAD + UMA 62mm bore + 28mm carb UMA
currently i'm using 14x42 which is not good for the above set.
in your current specs you need high speed combination, smaller sprocket like 38t and bigger pinion like 15t... IMO
parang naka superhead at 62mm bore narin pala
