White Smoke On Exhaust
retsam
asking ur help with this problem on smoke.
set up:
keihin 24mm carb
changed valve seal
newly changed 60mm bore kit
back to stock pipe (previously used nob1 and dbs pipes)
until now, there is still white smoke coming out. what is possibly the cause of this and how can it be solved? tnx a lot in advance for ur comments.
linjunvelasco
sir naka 60mm ka tapus naka stock pipe ka? sa vixion nga lang pag nagstock ka halos mapasu ka na sa init ng makina masasakal yan ser unless na modified mu na yung stock pipe mu
retsam
ng DBS ako una kaya lng umusok pa rin kaya try ko yung kalkal na stock pipe pero may usok pa rin..
macoolet
papa macoolet dba naka forged piston ka? ano size ng sayo at anong cam gamit mo? :D
hahahha uu naka forged...kung anong size yung hinahanap mo,yun ang gamit ko :D tsaka yy pang cams,pero palit CMS..
TS..anong kulay ng sparkplug mo..parang ok naman yung jettings mo...baluktot na valves,singaw,or maduming pipe na lang...
retsam
minsan po d na ngstart kasi umitim ang sparkplug.. posible daw flooded ang carb kaya affected sp sabi ng mechanic.
retsam
[quote="sniperCJ, post:
TS try mo rin check baka nahahalo yung coolant mo :)[/quote]
saan po posible nahalo sir? sa gas? saan sya titignan kung nahalo nga?
