linjunvelasco
its ethanol
so its normal?? xcs gasoline koits ethanol
its better to Check your Sp sir..for plug reading..if you cant do it, go to a trusted mechanic..so its normal?? xcs gasoline ko
ok paps salamatits better to Check your Sp sir..for plug reading..if you cant do it, go to a trusted mechanic..![]()
same hir.. but not 10mins.. i think 20-30secs..Subscribing,,,is this really normal???if we replace to a bigger Carburator is there really a white smoke came out in the pipe,,or maybe i didnt get the exact tune of the jets...my Carb is Keihin 28mm round,,my main jet is 105 & my pj is 38..when i start every morning the accelerator always get wild,until it gets to normal idle after 10mins.pls advise anyone........![]()
hard starting kba,,nbabasa po ng langis SP m sir,,,try m tnggalin punasan,,tingnan m po kung my lalabs p n usok,,tenxbago po bore kit ko walang gasgas yun eh..
sir paano ko malalaman na carb setting ang dahilan dahil umu usok ang snipee ko?? hndi kaya my gasgas na cylinder ko?? or sira piston ring ko?? setting ng a/f ko.. 1 3/4 turn out.. tpos pag ni rev ko.. my usok na lumalabas.. makikita ang usok kng my direct strike ng sunlight.. pagwala hndi ko nman mkita ang usok.. di ko lng alam ko tumatakbo na ako ng mabilis sa highway kng my usok pa na lumalabas.. basta pagnka tigil ako at ni rev ko na my direct strike ng sunlight.. mkikita ko ung usok.. anu po kaya problem?? 6k odo ng snipee ko at waswas mode ang break in from 0 to 1k odo..carb settings baka rich msyado?or baluktot ang valves mo at me singaw
di ko alam gagawin koPapz it could be a valve seal or Piston Ring problem just like papa sagad of SCOT, Waswas mode and a smoky pipe. Better let a yamaha 3's mechanic check it for you.sir paano ko malalaman na carb setting ang dahilan dahil umu usok ang snipee ko?? hndi kaya my gasgas na cylinder ko?? or sira piston ring ko?? setting ng a/f ko.. 1 3/4 turn out.. tpos pag ni rev ko.. my usok na lumalabas.. makikita ang usok kng my direct strike ng sunlight.. pagwala hndi ko nman mkita ang usok.. di ko lng alam ko tumatakbo na ako ng mabilis sa highway kng my usok pa na lumalabas.. basta pagnka tigil ako at ni rev ko na my direct strike ng sunlight.. mkikita ko ung usok.. anu po kaya problem?? 6k odo ng snipee ko at waswas mode ang break in from 0 to 1k odo..di ko alam gagawin ko
hmm papz.. sometimes only.. like now the smoke disappear... i dont know yPapz it could be a valve seal or Piston Ring problem just like papa sagad of SCOT, Waswas mode and a smoky pipe. Better let a yamaha 3's mechanic check it for you.
6 months plng sniper ko.. bgo pa 2based in my experience, try to change first the gasket cylinder baka tumatagas na ang coolant mo kaya may usok at hard to start the engine!!
hehehe paps english speaking thread...check the spark plug if it is black and wet..it's not on the turn...the settings for your af mixture will depend on your sparkplug's burn result...it happened recently to my monster bike,they checked the head and block and rings,only to find out that it was the pipe because it's wet with oil...grrrrrrrrrrrsir paano ko malalaman na carb setting ang dahilan dahil umu usok ang snipee ko?? hndi kaya my gasgas na cylinder ko?? or sira piston ring ko?? setting ng a/f ko.. 1 3/4 turn out.. tpos pag ni rev ko.. my usok na lumalabas.. makikita ang usok kng my direct strike ng sunlight.. pagwala hndi ko nman mkita ang usok.. di ko lng alam ko tumatakbo na ako ng mabilis sa highway kng my usok pa na lumalabas.. basta pagnka tigil ako at ni rev ko na my direct strike ng sunlight.. mkikita ko ung usok.. anu po kaya problem?? 6k odo ng snipee ko at waswas mode ang break in from 0 to 1k odo..di ko alam gagawin ko
thank you so much papzhehehe paps english speaking thread...check the spark plug if it is black and wet..it's not on the turn...the settings for your af mixture will depend on your sparkplug's burn result...it happened recently to my monster bike,they checked the head and block and rings,only to find out that it was the pipe because it's wet with oil...grrrrrrrrrrr
if all the solution based in our experience and idea's here are no luck!!
asking ur help with this problem on smoke.
set up:
keihin 24mm carb
changed valve seal
newly changed 60mm bore kit
back to stock pipe (previously used nob1 and dbs pipes)
until now, there is still white smoke coming out. what is possibly the cause of this and how can it be solved? tnx a lot in advance for ur comments.
sir, gud day..
advise ko po is iparebore nyo ulit yung block sa masmaayos na machine shop, based on my experience nung newly rebore ung block ko nauusok din, papalit palit pa kami ng ring at halos maulol sa kakaisip kung bkt nagsusunog ng langis,. yun pla tabingi yung pagkabore, binalik namin yung old block tapos nawala yung problem ok na ulit...
